bentombed Posted Sunday at 09:08 PM Author Posted Sunday at 09:08 PM 2 hours ago, gstallons said: When you go and try to start the bike and turn the switch to the key on position , does the fuel pump come on for about two seconds and turn off? What lights sre on on the instrument cluster? Also are the headlights on ? Then when you crank the bike does the starter sound normal? everything that should happen does happen - except for the spark. lights, fuel pump, instruments all good. It sounds like it should - just does not kick over. I am now thinking ECU, as far as i can tell everything else is good
bentombed Posted Sunday at 09:15 PM Author Posted Sunday at 09:15 PM 41 minutes ago, audiomick said: Can you describe exactly how you came to this conclusion? The connector for the sensor has three pins. As far as I can tell from the schematic, one of them must be a shield connection that goes off to earth at the ECU end. The other two connect to pins on the ECU. If you can't find volts anywhere on the connector that the sensor plugs in to, bearing in mind that it is possibly only 5 Volts or something, not the full 12V, checking all the connectors involved is the first thing. I.e. the one the sensor plugs into directly, the one the ECU plugs in to, and any others in between. If those are all definitely good, maybe the ECU has a problem. I will double check - i couldnt get a reading off the cable the sensor plugs in to. I came to this conclusion as I had hoped that the sensor was the issue, it's not, there is something else going on. Will have to check the ECU. 1
Pressureangle Posted Monday at 01:56 AM Posted Monday at 01:56 AM 4 hours ago, bentombed said: everything that should happen does happen - except for the spark. lights, fuel pump, instruments all good. It sounds like it should - just does not kick over. I am now thinking ECU, as far as i can tell everything else is good The ECU tells the fuel pump to run, so it doesn't seem likely that's your trouble, though possible. To check the cam sensor depth, if you have no tools, hold the new and old ones up to each other so the end of each touches the flange of each. They will probably be identical so you can assume the shims that worked in the past will work with the new sensor. The shims are more likely to be dependent on individual case machining than difference in sensor length. Since you're already installed it, if the shims are in, ok. If you installed it without shims, pull to see if the reluctor has shaved the tip of the sensor. The schematic I have shows that the sensor is a simple analog coil, the third wire is in fact a grounded shield to keep AC voltage from messing with other electronics. The wires on the ECU side of the sensor connector should be tan and white, pins 7 and 12 on the ECU connector. With a second helper and a digital multimeter, you can test the sensor at both plugs for AC voltage output while you crank the motor. The coils are powered along with the fuel pump and injectors by the fuel pump relay. Fuel pump primes...Yes? pull an intake boot back, open the throttle and look with a flashlight into the open throttle body. When you first turn the key, or perhaps the run switch, the injectors should spray for a moment, to prime the engine. If you can confirm that you have fuel from the injectors and signal from the cam sensor, then we can look at the magic box. Until then, I'm with Dr. House; "It's never the ECU". 3
Lucky Phil Posted Monday at 02:29 AM Posted Monday at 02:29 AM Whats the battery voltage when do you you hit the start button? How old is the battery? 2
bentombed Posted Monday at 07:20 AM Author Posted Monday at 07:20 AM 5 hours ago, Pressureangle said: The ECU tells the fuel pump to run, so it doesn't seem likely that's your trouble, though possible. To check the cam sensor depth, if you have no tools, hold the new and old ones up to each other so the end of each touches the flange of each. They will probably be identical so you can assume the shims that worked in the past will work with the new sensor. The shims are more likely to be dependent on individual case machining than difference in sensor length. Since you're already installed it, if the shims are in, ok. If you installed it without shims, pull to see if the reluctor has shaved the tip of the sensor. The schematic I have shows that the sensor is a simple analog coil, the third wire is in fact a grounded shield to keep AC voltage from messing with other electronics. The wires on the ECU side of the sensor connector should be tan and white, pins 7 and 12 on the ECU connector. With a second helper and a digital multimeter, you can test the sensor at both plugs for AC voltage output while you crank the motor. The coils are powered along with the fuel pump and injectors by the fuel pump relay. Fuel pump primes...Yes? pull an intake boot back, open the throttle and look with a flashlight into the open throttle body. When you first turn the key, or perhaps the run switch, the injectors should spray for a moment, to prime the engine. If you can confirm that you have fuel from the injectors and signal from the cam sensor, then we can look at the magic box. Until then, I'm with Dr. House; "It's never the ECU". I will check all these things - I am very happy its most likely not the ECU - i would have been very sad if had bought a replacement one and not fixed the problem.
bentombed Posted Monday at 07:21 AM Author Posted Monday at 07:21 AM 4 hours ago, Lucky Phil said: Whats the battery voltage when do you you hit the start button? How old is the battery? its not old - I'll charge it up and test. 1
audiomick Posted Monday at 08:23 PM Posted Monday at 08:23 PM 18 hours ago, Pressureangle said: ... "It's never the ECU". But it might be the connections between it and the rest of the bike. 1
