gstallons Posted November 26 Posted November 26 Well , anytime you have a battery that goes from a voltage this high to a voltage this low this quick , you have trouble. 1
Lucky Phil Posted November 26 Posted November 26 13 hours ago, bentombed said: that would explain it - i'll get a new one. Whats the tell? Instant low voltage under load. Phil 1
Pressureangle Posted November 26 Posted November 26 16 hours ago, bentombed said: Hey again - fully charged the battery was at just under 13v - with the bike on dropped to 12.7 - hit the starter it dropped to 10.3 the battery is less than a year old, but it could be the issue ^ Phil said it. Each of 6 cells in a 12v battery has nominal 2.2v. If one cell is dead or shorted, it will show full voltage while open-circuit but any load kills it's voltage, so you read the remaining 5 cells x ~2v. 1
audiomick Posted November 26 Posted November 26 (edited) 11 minutes ago, Pressureangle said: If one cell is dead or shorted, it will show full voltage while open-circuit but any load kills it's voltage, so you read the remaining 5 cells x ~2v. I have learned that if the battery goes under 10 V with lights on and press the starter, it is probably dead. Splitting hairs, though, in the light of that. However, it might be worth the attempt to see if the starter motor is ok. If it is reluctant, it might just load the battery down enough to make it look bad. One way of testing is to take it out and apply 12 V at the appropriate connections and see if it spins. EDIT: I just looked back at the first post, and read that the starter is spinning. So it is not jamming, and the "dead battery" theory is probably the right track. I'll leave this up though, just for posterity. Edited November 26 by audiomick 2 1
gstallons Posted November 27 Posted November 27 It is my understanding that you can make a quick evaluation of this. A 12v battery going to 10v means one (2v) cell is bad. 1
bentombed Posted November 28 Author Posted November 28 (edited) ok - i'm stuck now. new battery, new crank sensor, signal tested good, cleaned up the fuel and injectors, checked all the fuses, checked the relays, coils tested as good, everything that should work does. the problem remains. I have no power going from the injector relay to the injectors and coils, the relay itself clicks like it should. no spray from the injector when i switch on the motor or hit the start button, no power to the coils. its not the kill switch nor side stand switch. i have no idea what has gone wrong here. my non mechanical deductional powers say either try running your own wires from the injector relay, replace the ECU or find an auto electrician. i just wanna go riding again. Edited November 28 by bentombed
bentombed Posted November 28 Author Posted November 28 one other thought - on the wiring diagrams there is a warning light on the coils circuit, point 44, if this connection was out the circuit would be incomplete and could possibly be the cause of my lack of spark. where abouts would i find this light on the bike? one of the dash lights?
orangem2 Posted November 28 Posted November 28 (edited) How many shims were installed on the old sensor? If 3 and original they should be of varying thickness, remove the thinnest shim and try again... I had the same issues as you when I replaced the oring on my bike to fix an oil leak. Bike would spin but never start. When you see how thin that shim is, you will not think it would make a difference but it does. Edited November 28 by orangem2 1
orangem2 Posted November 28 Posted November 28 47 minutes ago, bentombed said: one other thought - on the wiring diagrams there is a warning light on the coils circuit, point 44, if this connection was out the circuit would be incomplete and could possibly be the cause of my lack of spark. where abouts would i find this light on the bike? one of the dash lights? The power for the coils and injectors comes from the injector relay... (44) has nothing to do with power to coils or injectors 2
docc Posted November 28 Posted November 28 @bentombed, apologies for my simplistic response, but have you tried starting while sitting on the bike with the sidestand up and the clutch pulled ? 1
orangem2 Posted November 29 Posted November 29 (edited) after re-reading the entire post... I saw in the pics a BUNCH of less than good looking splices in the pics you provided. first: check continuity first, can you check the power wires from the injectors and coils to the injector relay for continuity? no power, just for continuity... they all should read to each other: coil to coil, coil to injector, coil or injector to injector relay base. Start with that and we will move on from there. Edited November 29 by orangem2 3
bentombed Posted November 30 Author Posted November 30 On 11/29/2025 at 12:49 AM, docc said: @bentombed, apologies for my simplistic response, but have you tried starting while sitting on the bike with the sidestand up and the clutch pulled ? thats all good - sometimes the simplest bit is the problem - yes. Many times. i even tried manifesting spark 3
bentombed Posted November 30 Author Posted November 30 On 11/28/2025 at 10:40 PM, orangem2 said: How many shims were installed on the old sensor? If 3 and original they should be of varying thickness, remove the thinnest shim and try again... I had the same issues as you when I replaced the oring on my bike to fix an oil leak. Bike would spin but never start. When you see how thin that shim is, you will not think it would make a difference but it does. i will try that today - there were 3 and the o-ring was shot. I'll pull it and check them all again. I am using the 112 viton o-ring as suggested on this forum somewhere. I will do the continuity testing as suggested too, the previous owner of the bike did some very cool things, but also some odd things. thank you mr @orangem2 2
bentombed Posted November 30 Author Posted November 30 quick update - the continuity between the injectors and from the injectors to the relay is good. thus far, for the coils not so good - no reading between the coils, from injector to coil or from coil to relay, i will try again with thinner mulitmetre probes though. after lunch i will take a look at the sensor. some progress! thank you! 2
bentombed Posted November 30 Author Posted November 30 3 hours ago, bentombed said: quick update - the continuity between the injectors and from the injectors to the relay is good. thus far, for the coils not so good - no reading between the coils, from injector to coil or from coil to relay, i will try again with thinner mulitmetre probes though. after lunch i will take a look at the sensor. some progress! thank you! more update - continuity the whole way through, from coil to injector and coil to relay. My new crank sensor is a touch longer than the old one, I'll figure out how to measure the gap properly. 1
