wheelsucker Posted May 31, 2008 Author Share Posted May 31, 2008 I have the same problem. Going along @ 3-4k steady gas it coughs cuts out then back on. Plugs black loaded a nother map same thing took out the power commander problem solved bike and plugs fine. Lost some of the good the power commander was doing for the midrange will contact them as to the warrenty on monday . before you took off the PC, did you try loading a zero map or did you completely disconnect it? Link to comment Share on other sites More sharing options...
