slowkitty Posted September 30, 2009 Share Posted September 30, 2009 It's strange that I should only notice this like 2 years after I bought the bike, but my scura runs hot. I mean, I am going like 90 km/h in a 30 degrees centigrade ambient temperature and yet I felt heat on my inner thigh (right side) and bum (right side too). Was wearing a thin pair of jeans but I do not think that that is the problem; not the first time I wore that on my Guzzi. What you guys reckon? Sign of any impending mechanic failure? I do not ride the bike often enough, BTW, have a couple of other bikes. Cheers Link to comment Share on other sites More sharing options...
Dan M Posted September 30, 2009 Share Posted September 30, 2009 It's strange that I should only notice this like 2 years after I bought the bike, but my scura runs hot. I mean, I am going like 90 km/h in a 30 degrees centigrade ambient temperature and yet I felt heat on my inner thigh (right side) and bum (right side too). Was wearing a thin pair of jeans but I do not think that that is the problem; not the first time I wore that on my Guzzi. What you guys reckon? Sign of any impending mechanic failure? I do not ride the bike often enough, BTW, have a couple of other bikes. Cheers Tough call. If you can compare head temp side to side to see if the right is indeed hotter, that might give you a clue if anything is wrong. An infrared gun works well for this. Lean running can cause more head temp. If your bike is running fine and making no unusual noises, I wouldn't worry too much. I noticed more seat heat after I had a gel pad installed in my seat. They seem to hold heat more. Link to comment Share on other sites More sharing options...
fotoguzzi Posted September 30, 2009 Share Posted September 30, 2009 what do the spark plugs look like? Link to comment Share on other sites More sharing options...
slowkitty Posted October 1, 2009 Author Share Posted October 1, 2009 Will go check the plugs when I can. Thanks. The other thing is that the bike cannot idle for long; after about 3 minutes or so, even when warmed up the idling will slow down until it stall. Unrelated issue (to the heat issue) of adjusting the idling? Link to comment Share on other sites More sharing options...
