After years of discussion about the supposed change in fork angles via the triple clamps for later V11 Sports (post early 99 models) I took the opportunity to measure the top triple Scudd sent to me and I received today. If the fork angle had been changed by machining the clamps there's no evidence of it that I can see. On the granite surface plate the upper clamp fork bores are perpendicular to the stem bore so there's not angle change there. Another V11 myth debunked?
And so, the plot thickens . . .
Now we can say there was more than one change to the V11 fork geometry.
1) Very early V11 Sport, 1999 to very early production 2000 (before March 2000) may have been fitted with 45mm offset triples from the Sport 1100/ 1100 Sport-i. The resulting short trail, along with the short "RedFrame" and tire selection (soft, triangular profile Pirelli Dragon Corsa) were a formula for instability.
2) 40 mm offest triples were introduced (as early as March 200
