MINNESOTALEMANS Posted September 23, 2006 Share Posted September 23, 2006 sorry about puting the question in the spot. torque arm bushings on my 02 lemans or shot front and rear the dealer said guzzi only sells the whole arm not just the bushings i dont need the whole arm($) will the bushings from a R11rt fit they look very close to guzzi size?????? Link to comment Share on other sites More sharing options...
guzzi jon Posted September 24, 2006 Share Posted September 24, 2006 Your post caused me to look at mine, they are shot after 12K, if not available from guzzi, I'll maching nylon or urethane replacements. Let me know if you find a source, if not, I'll run a few sets for others.. Jon Link to comment Share on other sites More sharing options...
Paul Minnaert Posted September 24, 2006 Share Posted September 24, 2006 this topic has been here before, try the search function. The current ones are vulcanized in the aluminium. Link to comment Share on other sites More sharing options...
Skeeve Posted September 24, 2006 Share Posted September 24, 2006 Replace the whole thing w/ a proper set of Heim joints & Ti tube? [W/ some zerk fittings also, so you can keep the spherical bearings lubed & make it a 1x deal...] Link to comment Share on other sites More sharing options...
