LED Indicator Lights
Gottagetone
Just pulled it all apart and think I can make this happen, thank for your help and pics.
What about the brake light, not sure if you can just replace the relay to make that work?  Thinking about a brake bar with the LED light bolts to light up the license plate.
Those look kinda cool.  I am thinking about doing something similar to Waspp's setup except I want to put the plate up under the seat rather than have it hang below the brake light.  I found a single LED that I can mount under the seat area to light up the plate and stay legal.  I think this will look cleaner and those pesky toll road cameras won't be able to see it... :pic: .
In March here in Texas they are doing away with inspection stickers, you will still have to have an inspection done as it will be required to get your yearly registration sticker.  I hope to have this setup ready to go when the law changes.  Right now my inspection sticker has to be visible from an officers point of view while moving.
Good to know, thought you needed something to change the full power like the turn indicators.
Revival has a dual element circuit for $7 - http://revivalcycles.com/collections/for-your-ride-electrical-components/products/led-dual-element-circuit
or there is this http://revivalcycles.com/collections/for-your-ride-electrical-components/products/motogadget-m-stop which will create a flashing effect when braking which I kinda like.
Cool!  Make sure to post up pics when you're done...  I'll take a pic of my Aprilia brake set-up...
