I apologize for the lack of updates on my Laverda Fairing. I have two brackets mocked up and life overcame any more progress. Once thing I have noticed is that my fuel tank is much closer to the left cylinder head than the right. I think the tank is riding on one of the charcoal canister lines that routes to the right and above the air box. Has anyone else seen this? Maybe my hose is mis-routed.
I happen to have the tank off right now. I measured 124mm from spine to base of LH rocker cover, and 133mm from spine to base of RH rocker cover - the same 9mm difference that Docc mentioned. The V11 "hangs to the right." But it's only offset from center by half of 9mm (4.5mm).
Not sure what to do with this information, but at least we saved Craig from trying to straighten his out.
What a bunch of geeky motorheads we are.
