2002LeMans
Everything posted by 2002LeMans
  1. 2002LeMans
    2002LeMans
  2. Thank you ! That confirms my calculation .and why the 264 mm axle is too short.
  3. The 2 first axles 01614180 and ----85 are for Ohlins forks 1st and 2nd series The Marz 43 mm have a hollow axle and a nut.
  4. Yes you are right. See the calculations I made with the 2 manuals. Sorry I could not post the images( too big ) . Could you please measure your axle through the hole across the wheel and tell me to confirm the length of the axle ? Thank you. that would help very much. You are not far. I am in Los Angeles.
  5. Here is what I have from the 2 manuals. I have exactly the same configuration as on the 2003 picture with 162 mm between the 2 legs. But the axle I was shipped from Italy is 264 mm long ( same length as the 2002 solid axle ) and is too short. It needs a 270 mm axle with the calculations from here . and a different length of the 30 mm diameter end ( 64 mm instead of 59mm for the 264mm axle ) That is why I am asking if someone could measure the axle of 2003 LM ( Marzocchi 43 mm ) through the hole across the wheel it is easy . to verify the length needed. Because there are no specs anywhere to be found. That would help.Thank you. 1- Picture of 40 mm fork from Moto Guzzi V11 Lemans 2002 Manual If you add the dimensions indicated : 165 + 22,5 + 22,5 + 22,5 + 11 + 19 = 252,5 mm then the 264 mm axle is correct . it leaves 7,5 mm for the nut to thread. - 2- Picture of 2003-2004 V11 Moto Guzzi manual for 43 mm fork If you add 162 + 24 + 24 + 24 + 26 = 260 mm - then the 264 mm axle is too short .
  6. Oh, right! Maybe four variants? Early (40mm) Marzoc's could have the axle threaded into the left fork leg or through bolted to a lock nut. I had thought the later 2003-2005 (43mm) Marzoc's were hollow, but forgot all about the Öhlins! yes you are right .The 2002 threads into the left peg .No nut. and solid axle. The 2003 is a hollow axle.
  7. Would someone be able to tell me the length of the front axle for a 43 mm Marzocchi fork ? And if you know the MG reference number. There are 3 different models listed in the parts catalog . The 43 mm Marzocchi fork has a longer axle than the 40 mm.
  8. I bought a Le Mans not running with 3 k miles. Did the obvious work with tank,fuel hoses,filter,oil ,filer change etc... It started immediately but it runs a 4000 rpm . I found that the crankcase breather hose was broken and replaced it thinking that was the cause of an air leak . Same result. Any body can throw something serious ? Thanks. JPh
