I assume the ZFAS-S2 is not readily available to consumers now that I've read your post.
Here's what I had planned to ask:
What's the story on the plugged 10mm holes on the V11S exhaust pipes? Does Guzzi use some special tiny O2 sensors for tuning at the factory? The O2 sensors I find available seem to use the 18mm thread, but The ZFAS-S2 uses 12mm. See it here:
http://www.ngkntk.co.jp/english/products/e...nsors/p_03.html
Could the Guzzi 10mm holes be opened up and threaded for 12mm?
So I guess this is a mute question.
Troy
Todd, Thanks for the prompt reply.
My Piersburg pump developed a short. I cut the aluminum can with a pipe cutter at 7/8" from the output end of the pump and it came apart with no damage to the components. This thing is a work of art on the inside. If I can clear the short I might try to seal it up and use it again. I think Piersburg makes good stuff and I just got unlucky. However, they warn against running the pump dry, which I'm prone to do when I forget to open the petcock.
Best regards,
Troy
I'm ISO a Guzzi part number and a likely USA source for the external fuel pump, Piersburg 02T077, 7.21287.03, for an early '03 V11S.
I expect Guzzi to want my first born son in payment, so I'm looking into a generic replacement as well.
Thanks,
Troy
RE Thin 32mm Wrench
Ratchet wrote in post #3:
"The adjuster nut is 32 mm.
Unless you fab up a custom wrench, or happen to have an ultra-thin specialty wrench on hand, the top triple clamp has to come off for access. If you find one available somewhere, please do advise!"
Here's a thin 32mm wrench on sale for $8.00. It looks like 8-side, but one might grind the back out to make it 6-side.
http://www.icyclesusa.com/catalog/new/park...dset-wrench.htm
Troy
