britespark
Everything posted by britespark
  1. britespark
    britespark
  2. Hi all. Mine stuck in 4th. No problem starting, but came to a junction and decided to try it again. Went down to first and stayed there. I learned that downhill with brakes on, the pawl will fall foward enough to allow gear changes. I discovered this when I replaced the spring. It pivots from the rear, so braking and downhill will allow changes. I had to ride home in 1st gear. Hope this might help someone ger home easier. Pat
  3. There are 5 relays on right side under the seat. Pull out the front one, it has 5 pins. Pull the second one and plug it into the first socket. If it now starts, you need the 5 pin relay. That's what my problem was. Pat
  4. Ta very much. It appears these fitting mount inside the brackets for the footrest hangers. This explains why the rack rails are narrower than the footrest hanger brackets. I'll be able to make something now I understand. Cheers, Pat
  5. Hi folks. I'm new here, but I have learned a lot from your entertaining and informative Forum. I recently got Guzzi's own branded rear Alluminium rack, and it came complete with no fitting kit!. Does anyone have one of these fitted, and if so post some photos of how it attaches to bike. Help on this would be greatly appreciated. Thanks, Pat.
