Jose Paulo
Everything posted by Jose Paulo
  1. There are a nut cover on the top yoke. I dont know how to remove it.
  2. I NEED TO ADJUST STEERING BEARING, BUT HOW TO REMOVE THE NUT COVER FROM TOP YOKE?
  3. I have the direct link race performance program and when the bike stoped the temperature goes to about 50 Âșc at idle.
  4. I have a Ducati 749 and temperature air sensor is located on front noise. No change in temperature despite the velocicty.The Guzzi V11 have the sensor on box air and the heat from motor changes the temperature. If you have high vel them low temp. , low vel. give high temp. What do you think change sensor position?
  5. I think that is normal. My Guzzi V11 have the same "problem".
  6. Hi. When I have low fuel, the bike start to have bikefire and want to stall. No tank suk problem and I replaced the eletric fuel petcock to a manual. IS it normal? thanks
  7. May be two injections per stroke? the first inject more fuel than first? I had a poor idle if tps set 150mv. If you see the front cylinder table, idle inject 21us. I modified to 24 Now I have a perfect idle. I dont modified the rear cylinder fuel table.
  8. why the numbers in the front cylinder fuel table are not the same on the rear cylinder fuel table in the program Direct Link Race Performance?
  9. When I pull the clutch lever I hear a metallic noise, what is wrong? It's the clutch disc or the bearing clutch? My Guzzi V11 have only 13000 km. Thanks.
  10. I bought it a few days. It have a accident( head guard, brake lever, right side, no mufles). Sorry, I dont understand " running very well". I am not running yet. I am from Brazil. My english is not good. Is the first time that I see a Guzzi. Great Machine
  11. There are one nipple on bevel box and two on the gear box ( like manual, page 124 greasing the shaft, fig. 38), or its is inverted like my V11?
  12. HI, IM FROM BRAZIL.I HAVE A V11 SPORT PURCHASE A FEW DAYS. THE TUBE FROM PRESSURE ADJUSTER IS DISASSEMLY. IS IT A ASSEMBLY ON THE LEFT THROTTLE BODY? THERE IS SOME PROBLEM STAY DISASSEMBLY?(NO CANISTER) THANKS
