cashaden
Everything posted by cashaden
  1. Hello all - I have a 1996 Sport 1100 carb with the stock exhaust Does anyone have a new/used/cracked/broken crossover or an aftermarket exhaust system, with or without mufflers, available? I know it's a long shot, but it's worth asking. Warning, you may see my plea on other guzzi forums! Thanks!
  2. I am also looking at rejetting. I took a look this weekend to see what type of jet I had, and the only difference I found was that the idle jet was 55 on one and 52 on the other carb. Also found that one of the mixture adjustment screws was missing the smaller shaft at the end of the screw. What size jets did you end up going with? I was considering using the recommendations from Ed's write up on GuzziTech."http://www.guzzitech.com/lemansjetting-ed.html" I also believe I may be missing the pump jet on one of the carbs. I will have to post a picture so that you experts can take a look.
  3. Hello all, I am not sure if this is the correct area to be posting this, but here goes. I have a 1995 Sport 1100 Carb with the factory exhaust setup. I am in the market for an aftermarket crossover, or full exhaust. The ideal exhaust would be a full termi system. I have seen the one crossover on MGCycle, but I have not heard good things about the Stucchi x-over, and $425 for only the crossover, I might as well get the D&D full exhaust and upgrade the silencers later. So, my question here is, does anyone else know of where I can find and new or used x-over or full exhaust system? Heck, I would take a broken x-over, I can get it welded up. I have a call into MotoInternational, so hopefully they will get back to me soon. Also, is there a good place in the US where I can find salvage parts? Thanks in advance for your help. Casey
