Stinga
    1997 1100i Sport
Stinga's Achievements
Rookie
Rookie (1/5)
0
  1. Stinga
    Stinga
  2. Good on ya Gav, Yep got the serial interface so my lappy can strike up a dialogue with da ECU, hows that for nerdy talk, also got the valve lash set at 0.15in/0.20ex . So what I might do is set me TPS back up to 54 then use the slider in the idle cell to richen it up to slow da revs down. Then maybe reduce the map 10% between 3k to 5k so to improve the mileage but not starve it in the high revs and leave it alone between 2k and 3k so as not to reintroduce the hick-ups again. Raz suggested his map because I have the air box with a K&N filter with 3 X 1" hole to-wards the rear of the lid and a set of Staintune pipes and cans, like his. I think his geological position compared to mine might be the reason that mine runs lean up in the high rpm's. Just one other thing did you notice a 300 rpm reduction on the taco compared to the stock ECU, mine with the stock ECU is sitting on 4k @ 120 kph but with MyECU it's doin 120 kph @ 3700 rpm, this also the same at idle. Steve
  3. Cheers Mad Farquhar, Got your map in at the moment but when I set up the TPS, idle speed at 1200 and bodies balanced as per the manual using the stock ECU I then put in the MyECU and I get get a reading of 54 for the throttle position. So I configure the the ECU for 54 load your map start it and the thing idles at about 2000 rpm so screw out the idle screw to get it to idle at 1200 and then I get a TPS reading of 37. Bike runs hard and with no hick-ups between 2000 and 3000 rpm's and with only a bit of a miss at about 6500pm but it drinks fuel at 15kms/Lt @ 130kph ( stock ECU 18.5 kms/Lt )and during cold starts with full choke on I still have to use some throttle to get it running. Will try to lean out whole map and maybe go back to 54 on the TPS nd adjust the idle speed as per Raz's way. Raz's map works OK and at 54 TPS but has some fluffiness/jerkiness around at 120 kph or 2700 rpm with a steady throttle and misses heaps above 6000 rpm and wont even reach 8000rpm but starts real good with choke, maybe this map needs to richened up. With Cliffs map I can only get it to run using TPS at 67 but some times it idles @ 1200 then jump to 1500 rpm then it will die to about 800 rpm or stall and when I take it for a ride the thing sill has the same jerkiness at 2500 as the stock ECU and when throttling off there is heaps backfiring through the exhausts. I know that the ECU is not a Plug-and-play but there is some tuning to be done but I don't have the patients or skills to f$&k around with it and if I want to get it really right I have to spend another $500 on an Optimiser and Lambda probe or try a get someone willing with a Dyno to tune it, but that could cost another $500 to $1000. Now don't get me wrong this thing is a great piece of kit with it's complete tunability over all the spectrum's but for non computer nerds like me it's a bit perplexing but I will persist.
  4. Do ya reckon you could upload and attach your map, because I am having a few problems trying to get mine right. If I use the map that Cliff supplies it still has he stumbles at about 2500 rpm and has a lot of backfire when throttling off.
