dbarb3
Everything posted by dbarb3
  1. dbarb3
    Rear Brake Lever
    Had little tip over, looking for a rear brake lever 2002 Lemans
  2. YES Fuse looked fine Problem solved and I am thankful for the help No other group like this one
  3. Thank you everyone After Gene talked me into using a test light I'm embarrassed to say 2 perfectly good looking fuses were the culprit
  4. I have a feeling gonna have to pull tank and start looking Really good charge none of the lights we discussed are working
  5. Charged battery for a few Battery 13.1 Fuses 6 12.2 Fues 7 12.3
  6. dont have a test light unfortunatly I will test battery and check voltage
  7. 6 11.6 7 11.8
  8. Well I can tell I dont ride much at night I am not very observant Tail light, tag light, city light, intrument lights are all out Good grief
  9. Will check other lights referenced
  10. 2002 external fuel pump it starts up when key is turned on
  11. Switch key on main headlight comes on
  12. Front 7 have 12 V last fuse (rear) has none I will check my headlight
  13. Headlights dimmer horn work brake light works How do I check the ignition swith ? Come in from under it? Talk to me like a 3rd grader on testing the voltage I have a multimeter but thats about it.
  14. Well not surpised new flasher did not fix it Also noticed my tail light isnt lit but the brake light comes on when applied
  15. Found it Round metal one says Wagner 552 12 V Seems Auto Parts has these Gonna replace and see whats up
  16. Thank you gentlemen back to the garage I go. Appreciate the help.
  17. I have looked pretty good under seat around fuses box, relay, tail section and if flasher looks similar to auto one I sure dont see it
  18. Signals do nothing at all -- dead Where is flasher I didnt see it under seat its 02 Lemans
  19. Start out by saying I hate electrical problems. The mechanics of this bike are perfect but some of these niggles are frustrating. I have checked fuses and thats about the depth of what I know to do. Front and rears both are out.
  20. If its rectifier check your connections and make sure you purchase one that has matching connections and will plug and play. Saves a lot of hassle.
  21. Riddle seems to be solved - Angle Drive But I still do not understand.. It turned by hand, it turned by rolling motorcycle. It turned cable going down road disconnected from speedo. But when I connected cable to both different speedometers it would work for about 4 miles and start fluttering and quit. No idea whats wrong with angle drive other than a new one seems to have corrected problem.
  22. Got what I needed thanks everyone
  23. MG showing out of stock
  24. LaGrasta sent you PM
  25. 2002 Lemans with white Veglias Shot in the dark, anybody have a angle drive that they will part with
