Hi all,
I have a new-to-me since March, 2001 V11 sport, that I have been sorting.
It has about 9500 mi, Magni fairing, PCIII, and some unidentifiable carbon cans that look like the FBF but are more round. The crossover looks stock.
At delivery, it started and ran fine, but would hiccup in the 2500-3000 rpm range with light throttle openings. This progressed to almost complete loss of power at all throttle openings when steady state cruising from 2-3k rpm.
I had the valves adjusted, oil changed, gearbox fluid change, new fuel filter, with no change.
I then had a PC dyno tune by a shop not familiar with MG's (mostly Harley) but the only thing close with a dyno.
There was a noticeable improvement, and the bike is now quite rideable, but there is still an occasional hiccup on decel or with light throttle.
Next up is, of course, TB sync and TPS setting. Will have to tackle this myself, soon as I muster the courage and meters.
Have also lost the tach, lights and horn, usually happening on hot restarts. Waiting for my new relays in the mail.
My dyno graph also showed the "typical" midrange dip, but otherwise looked similar to those seen on this site.
I am thinking about adding the Mistral crossover to improve the midrange, and add some sound.
Questions:
1. Will it work with the center stand, and do I need to modify it to work
2. Do I need to go back on the dyno for another PC tune after its installed (might be a hassle, not a convenient place)
Thanks
