BRENTTODD Posted October 15, 2007 Share Posted October 15, 2007 My neutral switch on the trans is starting to leak a little oil. Is this pretty common, and do i just order a new one or is there more to this I dont know about ? Link to comment Share on other sites More sharing options...
Tom M Posted October 15, 2007 Share Posted October 15, 2007 If tightening it doesn't stop the leak you'll need to seal or replace the gasket or o-ring (I don't remember which it has). I had to replace my whole switch when it stopped working and I think it was about $45. Silicone gasket sealer is lot cheaper than a new switch Link to comment Share on other sites More sharing options...
Greg Field Posted October 15, 2007 Share Posted October 15, 2007 I think it's a 10mm crush washer under the switch, but that's just from memorey. Try tightening it a 10th of a turn. Link to comment Share on other sites More sharing options...
BRENTTODD Posted October 15, 2007 Author Share Posted October 15, 2007 I'll try tighten it let ya know how i make out with it thanks Link to comment Share on other sites More sharing options...
BrianG Posted October 16, 2007 Share Posted October 16, 2007 I know it's not a bit that sees much removal/replacement, but those crush washers harden over time, with heat cycles and with re-use. If the seal is where it's leaking you can anneal the crush washer to re-use it, or just replace it. I prefer copper crush washers to aluminum ones, but that's just me. Link to comment Share on other sites More sharing options...
BRENTTODD Posted October 16, 2007 Author Share Posted October 16, 2007 I just snuged it down at work it did have about a tenth of a turn in it. I have 30 mile ride home Ill see what happens, but i think Greg could have solved my problem. Thanks to everyone for ther input Link to comment Share on other sites More sharing options...
