rear axle nut
Guest BIGGERJIM
Guest BIGGERJIM
hey yall
i was trying to get the rear axle nut off my v11 to grease the u-joints
and i can't seem to get the axle nut loose, i pure lifted the rear of the bike up
trying to break it loose.
i hope the bearing have survived the incredable torque they have been under
is it normal for them to be this tight.
is there something i'm messing beside the big axle nut.
thanks
big jim :huh:
Guest BIGGERJIM
i even tried the impact wrench while holding the allen wrench on the other side
is there a pinch bolt i'm not seeing
i picked up the back of the bike with a pry bar on the wrench.
boy lubing them u-joints are gonna be a pia :lol: .
thanks
thanks
I would try heating the nut with a torch. It may have been assembled with loctite red. If that doesn't work, I would try even more heat. Be careful with the paint on the swing arm.
Good luck, I think you will get it off.
Cheers,
Steve
Guest BIGGERJIM
hey yall
i broke it, but i had to whack it with a hammer and get a very long pry bar
but i broke it loose,
after supper i'M going to finish tearing it down, and attack them u-joints :o
THANKS FOR THE HELP
YALL ALWAYS COME THRU
BIG JIM :D
