Ohlins rear monoshock
Dimitris
Hi!
Anyone knows the Ohlins code number for the Ohlins rearshock of the Rosso Corsa-Scura models?
As far as the Ohlins front forks, the code is FG313, am I right?
Should be pressed in, I think the scura and later models had different tuned rearshocks, but I'm not shure.
Forks are 313 right. You won't find much on them at the ohlins site because they are made for guzzi.
I think there is a topic that has the numbers:
http://www.v11lemans.com/forums/index.php?showtopic=9000
  • 2 weeks later...
This was on the forum from July 3 2002 from
al_roethlisberger@yahoo.com
Sanford, NC USA
BTW, since there have been some lack-luster reviews of the rear OEM Ohlins shock on the Scura (justified or not rolleyes.gif ) ... here is Ohlins direct replacement for anyone interested:
Brand Model Year
Moto-Guzzi V11 2002
Öhlins shock absorber
Part No. Type Position Comment
MG 127 46HRCS Rear "
• Type 46PRC with hose mounted reservoir, easy to fit where it is easy to reach.
• Fully adjustable single shock absorber.
• Improved cooling gives more consistent damping and longer damper life.
• Features compression, rebound and hydraulic pre-load adjuster.
Hi!
