MINNESOTALEMANS Posted June 10, 2009 Share Posted June 10, 2009 how do you remove the clutch lever (stock one) mine moves up and down in the mount on the handle bar is there a bushing in the mount pin ?? and how do you get the pin out i took the nut off does it turn out? i cant get it out!! 2002 lemans Link to comment Share on other sites More sharing options...
gstallons Posted June 10, 2009 Share Posted June 10, 2009 Huh? If you are attempting to remove the lever only, remove the nut underneath the pivot bolt. Push the pivot bolt up and out of the perch (while you watch for a ball and spring fall to the floor when you do the next step) and remove the lever. Reassemble everything and lightly grease everything you do not want to rust. Link to comment Share on other sites More sharing options...
guzzipete Posted June 12, 2009 Share Posted June 12, 2009 ...and how do you get the pin out i took the nut off does it turn out? i cant get it out!! 2002 lemans I needed to give mine a gentle tap from underneath with a rubber mallet. Link to comment Share on other sites More sharing options...
