docc Posted 3 hours ago Posted 3 hours ago 3 hours ago, orangem2 said: 2004 v11 Cafe Sport Oil pressure light ON with key ON, engine OFF GEI 20A/25A relays just ordered picker PC782-1C-12S-R-X replacement relays Thanks. Later V11 are wired slightly differently than the early Sports. On 10/17/2025 at 5:48 PM, orangem2 said: I read ALL of that already and then some LOL... just 2 questions: is my regulator rectifier borderline? should my charging light come on when the bike is NOT running, just the ignition switch to ON? 3 hours ago, orangem2 said: 2004 v11 Cafe Sport Oil pressure light ON with key ON, engine OFF GEI 20A/25A relays just ordered picker PC782-1C-12S-R-X replacement relays Look carefully at your warning light display. There are separate right and left turn signal indicators? Then there will be no "battery"/charging light. It was omitted on the later V11. Good call on the (major) relay upgrade. 2
orangem2 Posted 2 hours ago Author Posted 2 hours ago (edited) Also checked the 30A fuse... It was perfect with no degrading whatsoever. I will share results when new battery, and relays are installed Edited 2 hours ago by orangem2 2
