Rm K&n filter pics
richard100t
Its an rc 1200 & I dont know if it will fit a Centauro. Probably not though
45618[/snapback]
I don't see why not. With the airbox off, the remaining free volume is identical. I believe the throat diameters are even the same. Paul M??? You got a reading on this?
45650[/snapback]
Now that you mention it they should fit as long as the TB's are not larger than a v11's. Or extremely smaller (I doubt it). In any case its a cool mod & cheap too...Less than a hundred. They just screw on the TB's with a hose clamp
The TB from the 4v are much bigger, they have a 50mm diameter, and you should leave the cone on, so look for an even bigger diameter. I don't know the number, K&N isn't good at printing numbers on filters. The bigger the better, take as big as you have place.
