andy york Posted March 29, 2003 Share Posted March 29, 2003 I need a little help. I bought my 02 LeMans used. The PO installed the oil dipstick with the temp gage on it. There are no markings on it.Did the stock dipstick have graduations for high and low oil level, and if so, could someone tell me what they are. As measured from the bottom of the stick to the low mark and high mark.inches or mm's would be great! Thanks Link to comment Share on other sites More sharing options...
callison Posted March 29, 2003 Share Posted March 29, 2003 If I get a chance I'll meassure it. However, the measurement is taken from the base of the screw in part as the measurement is made with the stock dipstick fully threaded in. Yours and ours may be of different lengths and a measure taken from the tip would probably not be correct. Link to comment Share on other sites More sharing options...
Guest geezerx Posted March 29, 2003 Share Posted March 29, 2003 Andy, here's a shot of a dipstick from a 2000V11S. Can't gaurantee that it is the same as your bike but I don't know why it would be different. Note that the measurement (in inches) is taken from the part of the dipstick that is tight against the top of the opening into which it is inserted when obtaining reading. Carl, got a quick question for you. Relative to a post you made in response to a question I had regarding the tipover valve, do you have the stock airbox in the bike you refered to? Link to comment Share on other sites More sharing options...
callison Posted March 29, 2003 Share Posted March 29, 2003 Yep. Stock everything except the Mistral cans and a PCIII. Link to comment Share on other sites More sharing options...
andy york Posted March 30, 2003 Author Share Posted March 30, 2003 got it. The dipstick measures the same. Now to put a low and high mark on it. Many Thanks Link to comment Share on other sites More sharing options...
