IGNORED
Rear Brake line correct Routing
  • 3 months later...
5 minutes ago, western trucker said:
It’s got me scratching my head as the little tabs are obviously missing and I have come up with a route but a bit suspicious in its routing
regards
I looked, before, for an image of this routing. This is as close as I ever got. The left retention tab is visible on the top of the rear subframe cross member just below the Carcano-green LuckyPhil/Chuck-made shift extender. There is a matching right side tab (a little further outboard), and another on the inboard side of the the left swingarm arm.
Link to post
Okay, this shows both retention tabs on the early RedFrame subframe. They are pretty hard to see with everything assembled. Easy to see with the wheel off . . . Also seen is how the brake line drops down from the right side.
Link to post
38 minutes ago, western trucker said:
Thank you so much that makes way more sense I was only missing swingarm tab the other two were there.
Again thanks
I only now realize the swingarm retention tab is visible in that last image forward of the caliper bracket pivot bolt through the swingarm.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
