igor
Everything posted by igor
  1. thanks everyone for your advices , after contacting a moto guzzi mechanic in belgium , they said that apparently you can put the new rubber without taking the body throttle out , ordered the pieces at TLM in Holland . Will keep you updated of the process . igor
  2. seems like everyone has a different solution
  3. that's a bit of a more reassuring answer ;-)
  4. do i really need to remove the aluminium manifold to do this ? could something in the motor been damaged because of what happened ? thanks
  5. can you replace it without removing the carburator ?
  6. Hi everyone , so yesterday i felt some air explosion on my left leg and the motor started to do some loud exhaust explosions , after stopping i realized the manifold was broken and ripped . So here are my questions , could this have cause some other problems in the engine , can this manifold be replaced without unmounting the carburator and would some have some links for this part in europe for my v11 le mans ? thanks a lot for your help here is a picture
  7. Hi, so you confirm the picker components PC782-1C-12S-R-X is the starter relay , because it's the one i think i seem to have problems with . Sometimes the guzzi will start directly and sometimes just a click and no starter action , so i switch the lights off and on try again and after 2 or 3 try outs it starts . Could it be this relay issue or do i need to look in another direction ? Thanks for your help
  8. Hi , Are all the relays on a V11 le Mans 2001 the same ? can you confirm that this model is a good one : Picker Components PC782-1C-12S-R-X Thanks a lot for your help
  9. hi everyone , Just to let you know that the starter i mentioned above works for the v11 le mans . Great price . See you
  10. thanks everyone i'll buy it and keep you updated
  11. i tought that with this info someone could maybe tell me if it fits A1: Volt 12 V A2: Power 1.2 KW A3: Teeth 9 Teeth A4: Mounting 2 Hole A5: Mounting diameter 62.00 mm A6: Rotation Counter Clockwise / CCW it says V11 sport i guess its the same as the v11 le mans ? thanks for your help Description A1: Volt 12 V A2: Power 1.2 KW A3: Teeth 9 Teeth A4: Mounting 2 Hole A5: Mounting diameter 62.00 mm A6: Rotation Counter Clockwise / CCW
  12. Hi everyone , could you tell me if this starter would fit on the v11 le mans 2001 ? thanks a lot https://www.simon-auto-shop.de/epages/Simon-Auto-Anlasser-Lichtmaschinen.sf/en_GB/?ObjectPath=/Shops/Simon-Auto-Anlasser-Lichtmaschinen/Products/S6035
  13. thanks i'll check that out . i guess you can find the right values for the relay in the manual ?
  14. thanks . hope someone had the same sort of issue
  15. Hi everyone I'm experiencing a weird electrical issue When i try to use the horn , it doesn't work and bring my rpm arrow back to zero each time i try to activate the horn . Any idea where it can come from ? thanks for your help
  16. thanks everyone for your help . Very interesting to see that you could put a 170 in place of the 180 recommended .
  17. Hi Docc , The ones mounted on mine are 180/55/17 Sould i consider another size ? what are the pro's and con's ? Thanks
  18. Hello everyone , I need to change the tyres of my v11 le mans . Bought it with Pirelli Angel on it , the rear is pretty worned flat in the middle , makes the handling a bit strange . What tyres would you suggest ? I was thinking on dunlop roadsmart 4 Thanks for your help . Igor
  19. thanks found the part on motorcycle spare parts ( cheaper than on other sites )
  20. here are the picture seems like the previous owner already put some silicone . found the part on motorcycle spare parts ( cheaper than on other sites ) Last question , do you think i should put some loctite on the bottom connection with the bolts ? Thanks
  21. Hi thanks for your answer . I dont seem to see any fixation screws from the rubber to the dash board unless the metal rounded piece thats now on the dashboard was supposed to be in the rubber , and now it snapped off the rubber part and stay screwed to the dashboard . Would it be a solution to glue it back together with some silicone ? I'll take a picture in a few hours to show it more clearly . For the brakes you're right i guess i'll go to a mechanic and ask him to show me . thanks for your answer
  22. hi everyone Today the dashboard of my V11 le mans got loose . Watching how it's fixed it seems it's just 3 metal pieces going into 3 rubbers with a hole in it . Is there a way to fix this and to be sure it wont happen again ? Is it the rubbers that got old ? Would love some advice how to fix this . Also by getting loose it placed itself on the right side of the handlebar and somehow unscrew a bit the bolt of the brake line fluid, so fluid went out . Now no front brake anymore . Is it easy to fix this ? I guess i have to put back brake fluid and purge the brakes , is it easy to do ? Thanks a lot in advance
  23. hello evryone , thanks all for your help , managed to fix the problem with some adjusting of the gear shifter . Thnaks again
