heh frankdugo,
The gage is a combination tach / speedo from Moto Spezial in Germany. You can get the large scale as the tach or speedo and vice versa. They were on sale for 290 Euro.
http://moto-spezial.de/homepage/index.html
Browse their catalog, wonderful special parts.
Thanks for the tip-'o-the-hat felix42o
It's been (and continues to be) a schwack of work and I would rather not think how much $. But what the hell, right? So I could have bought a restored 1975 MV America for the same money, so what?
Gotten a lot of bits and misc. pieces from Aircraft Spruce in Calif. They have all manner of fabrication stuff for home built airplanes that comes in handy for home built motorcycles too:
http://www.aircraftspruce.com/
The hydraulic fittings and line comes from Russell and Earls. I order from JEGS:
http://www.jegs.com/webapp/wcs/stores/serv..._10019_-1_10267
The black anodized fittings are a nice detail touch.
took a long time to fine a "gang" relay block (for master power, starter, horn (139db Stebel), and spare:
http://www.rallylights.com/hella/Relay_Block_Pictures.asp
Will be using an elektronik-sachse.de ignition w/ dual plugs:
http://www.elektronik-sachse.de/ZDG3/frset_zdg_en.htm
Will be equipped with Valentine 1 radar detector and Blinder M25 laser jammer & helmet heads-up display.
Plan was to use a 280 watt Saprisa alternator, but now figure I need to do a load tally and see if it's going to be able to keep up. May have to go to this rig:
http://www.euromotoelectrics.com/EDLMG.html
Then there's the JE pistons, Nikasil barrel plating, Mike Rich head work / porting, crank balancing, finding a V11 Sport clutch - flywheel, Yoyodyne floating ft. rotors, 40mm dellortos, dyno tweaking, Oberon turn signals, etc, etc, etc ..................................
Like I said about the 75 MV ........................... Big-Ass fun building this thing though. Target completion is next spring.
Curtis Harper ordered me up a Tenni fairing piece (in stock w/ MGNA) that was $60 & will be a way to match the color w/ Imron via local paint shop. Might be able to get a PPG code at the same time. Can post the code(s) after I get it done.
CFMAW
