canny
Everything posted by canny
  1. i had the same problem with my 2004 V11 Le Mans . i removed the standard DENSO flasher relay and fitted a Jap one that is designed to run LED`s , now the four LED indicators flash like they should .
  2. the unit does use LED`s , however the neutral & high beam on it are working fine - jus the low fuel & oil light with issues . i thin it`s time to call in a pro (cos it`s startin to do my head in) ............
  3. tacho`s sorted , thanks for the info . i made a 2" plate , fitted it to the lower brake caliper fixing bolt and attached the sensor bracket included with the kit to it - it gave inconsistant reasings at first so i moved the sensor as close as possible to the disc bolts - works a treat . i am using the units EOBD light as my low fuel level indicator , however neither that nor the oil light are coming on when the ignition is turned on (neutral light`s working fine) even though the oil light should and the fuel tank is almost empty !!!!! any clues ?
  4. Cant help you with your problem , but mmaybe someone can help me with a related issue . installed a KOSO RX2N console and all works fine except the tacho , it is not reading the rpm at all . after selecting the correct stroke and cylinder number settings , there is a high or low option for the input signal - have tried both but still no rpm reading on the console .......
  5. canny
    tacho failure
    hi guys . the speedometer counters packed up recently on my `04 V11 Le Mans so i decided to install a complete new console - a KOSO RX2N . everything`s working fine with it except that the tacho isnt picking up the rpm . i have tried to install the wiring as per the KOSO unit`s instructions ,but in my opinion they are fairly vague . anyone out there that has already fitted one of these units or can show me the way - it would be much appreciated . any info on calibrating the unit would also help . cheers Canny
