Everything posted by Mr. Bean
14,000 on my 04 Ballabio bought new at M.I. Unfortunately no long trips...only a few day trips on it. My work keeps me just using it mostly as my commuter on the daily I-5 slog. It has had no issues at all....well ones that I didn't cause anyway!
Greg, Who would you recommend around here to do a custom map on our Guzzi's? I would like to get mine done as well, but so far everyone I talk to either says "Moto what?", are Harley only, or just don't seem very confidence inspiring. Randy
Thanks for posting the pics. I like the look of those alot...gonna check into getting a set. Randy
The left hander on my Ballabio is starting to loosen up. I think I've bumped into it too many times in the garage. These look pretty good to me. How's the view compared to the stockers? Do you get to see less of your arms? Randy
A stoppie on the Ballabio? Ok, I'm impressed! If I tried that, doctors would spend weeks trying extract wadded up parts of me from the wadded up remains of my Ballabio....
Replacing rear brake caliper seals..........NOT!
Mr. Bean replied to guzzijack's topic in Technical Topics
This is a good place to get Brembo parts.... http://www.yoyodyneti.com/Category.aspx?CategoryID=3017 Randy -
Click on MPH Cycles at the top of this page. They have a page for Parts Manuals. Randy
Well, it's good to know I am not alone! I checked with Agostini's and they no longer carry them. Apparantly the manufacturer, (Stucchi?) has stopped making them. I'm hoping some dealer has one sitting on dusty shelf somewhere...just gotta keep calling around. Randy
I second what Ratchet said about Craftsman hex wrenches...I like Craftsman tools but I don't trust the hex wrenches anymore. Picked up very good set from Snap-On...pricey but they fit bolts on the Guzzi perfectly. As for the bolts, you may want to check out McMaster-Carr. Randy
Been very busy all winter and with the rather nasty weather we've had (for Seattle anyway,) didn't get too much riding in..just the odd commute now and again. I have been storing up parts for a large going over the bike and finally spent a day last weekend wrenching. Changed out the air and fuel filters, wired the headlight onto it's own circuit and relays (thanks Eastern Beaver,) dropped in one of Pete Roper's famous sloppage sheets (thanks Pete and Greg,) and generally gave the bike a good going over. After yet another busy week...today broke picture perfect. Time to ride! Went out for a quick 150 mile ride up and into the foothills...everything was working perfectly! Upon my return home I decided to reward the bike with a wash, but hey, "I'll let it cool down a bit while I hose off the porch and walkway." I drag the garden hose around the side of the house..."hmm, seems to be stuck on something...well I'll just pull a bit harder and...uh, oh. That didn't sound good!" Sure enough, the hose was apparently stuck on the now prone bike... First time in it's 2 years and 14k the bike has been on anything but it's tires or a stand...oh well at least I got away cheap..only a broken brake lever and a couple small scratches. Funny thing is, I've been trying to track down a crash bar for the bike for last couple months but no-one seems to have one anymore. So come on! Lets hear your stories...or am I the only klutz around here?
Here's what I did to solve the same problem... http://www.v11lemans.com/forums/index.php?...&hl=fairing Randy
When I fist noticed the same knocking noise on mine I asked the guys at Moto I. about it. They said it is the sound of the transmission parts reacting to the uneven power pulses of the engine at idle. That is why it goes away at anything above idle. They all make that noise I guess....works for me! Randy
You rock! Thanks! Off to the bike shop after work.... Randy
Ratchet...do you have some info on this wrench? I've looked around but have not found one that looks like it will fit? Thanks! Randy
Italjet Kit Kat 50cc??? or Carnielli Motograziella 50cc???
Thanks Gary. That is good to know. One of the things I liked about the Centech is it's small size..probably a result of using a printed circuit board. I'll try to find some mounting setup to reduce vibrations on it. Maybe something similar to the rubber insulating screws holding the CPU down? Given the risk I don't think I'll try hook any "important" stuff through it, only items like the battery tender and heated vest. I was toying with the idea of hooking up the new headlight relay kit to this rather than direct to the battery and replacing the in-line fuse from the kit with a fuse in this box. Randy
I second the vote on the TwinMax I know it costs more than water or mercury sticks but I find it WAY easier to use. Randy
Thanks for the good info everyone! I ordered up one of the Centech AP-1's for this little project. Randy
Looking for advice here... I'm thinking about adding an accessory fuse box to clean up the number of additional connections I have on the battery posts. Right now I only have a battery tender connected to the battery and it was a tight fit just to get those connected on top of all the other stock wires on each battery post. I share this same connection with my heated vest with an adapter but would like to put the vest on it's own connector. In addition, I have one of the Eastern Beaver headlight wiring kits headed this way and it too connects to the battery. I am assuming I can get a fuse box that has both positive and negative connections to the battery and then wire these accessories into the box with an appropriate fuse for each? Has anyone done this? If so, what type of fuse box, and where did you get it? Any tips would be very appreciated as I'm generally a hack with electrics! Thanks! Randy
Thanks for posting I've got mine on order and am looking forward to doing this also. Randy
That's a very noticeable difference I'm guessing the correct one to get is the H4 Single Headlight Relay Kit - shell mount? Has anyone tried the H4 Weatherproof Headlight Relay Kit version with the posi-lock connectors and remote relays? I'm wondering if there is enough room in headlight shell for all the stuff on the first one? Randy I should have read the webpage a little better. Sounds like they now give you the option of using posi-loc connectors on any version so only the relays would have to fit inside the shell with the first option. That sounds easier. Does this sound right? Randy
Nice job. I like the clean wiring install. Mine looks like a bunch of rodents have been gnawing at them. One of these days when I get really bored I'll have to clean it up and do it right. May copy your ideas. Randy
Question for all on the M4's. The ones I have seen on other bikes (never seen one in person on a Guzzi) all had a bright red M4 logo. Do all have these or are they removable? Randy
I have found that I can't use any polarized sunglasses while riding. Blacks out the screen on any LCD display and causes weird shading and coloration when looking through my clear Arai visor. My photocromatic lenses seem to work ok..they darken and lighten almost as much as when they are in the open. They are Ray-Bans...same ones I use for flying. Randy
First Ride Report of Summer 2007 (no V11 content)
Mr. Bean replied to Greg Field's topic in 24/7 V11
Great ride report Greg! I love the Neah Bay ride. It was my Ballabio's first true ride...only three days out of the crate there at Moto I in 2004. Since I was breaking it in, didn't really try to stay up with my buddy on his R6. I usually make it out there about twice per year....only I do it when the weather is a wee bit better! (I'm a wuss...it's pretty much just commuter riding for me in the winter.) We should try and hook up this summer and ride it again. There's a great Italian place in Port Angeles to stop at on the way back. Bella Italia. Randy
