BrianG Posted May 14, 2007 Share Posted May 14, 2007 I have recently greased the splines on the driveshaft of my 2000 v-11 Sport. The problem comes in the re-assembly. It seems that there is no vent in the shaft to allow the air out as one shaft slips into the other. I cleaned out the interior of the forward (female) shaft to be certain that I wasn't getting a hydraulic lock on compressing the shafts. But still, on reassembly of the rear suspension, there is a preload on the torque strut caused by the compressed air in the drive shaft. Is this normal? Have I missed something? Is something plugged that should be letting the air out? Wil this right itself with some riding? Link to comment Share on other sites More sharing options...
Guest ratchethack Posted May 14, 2007 Share Posted May 14, 2007 Not to worry, Brian. Yes it's normal, you haven't missed anything, nothing is plugged, and yes, by my experience air pressure behind the o-ring seal will work its way out with some riding. Link to comment Share on other sites More sharing options...
dlaing Posted May 16, 2007 Share Posted May 16, 2007 I have recently greased the splines on the driveshaft of my 2000 v-11 Sport. The problem comes in the re-assembly. It seems that there is no vent in the shaft to allow the air out as one shaft slips into the other. I cleaned out the interior of the forward (female) shaft to be certain that I wasn't getting a hydraulic lock on compressing the shafts. But still, on reassembly of the rear suspension, there is a preload on the torque strut caused by the compressed air in the drive shaft. Is this normal? Have I missed something? Is something plugged that should be letting the air out? Wil this right itself with some riding? The grease fitting has a one way valve. To ease re-assembly, poke the valve with something blunt but pointy and the air (and grease) can escape. What effect this has on riding, I don't know. Air suspension??? Link to comment Share on other sites More sharing options...
antonio carroccio Posted May 16, 2007 Share Posted May 16, 2007 Héy, we just discover more cush drive Link to comment Share on other sites More sharing options...
