kevdog3019 Posted June 11, 2007 Share Posted June 11, 2007 The new local Guzzi shop had our Lemans in recently for a shift spring. When my wife went to pick it up they told her it badly needed a valve adjustment. It makes a good bit of clacking for sure, but thought this was normal since having it. Have I just been ignoring the issue? I adjusted 4000 miles ago for my first time. They have only heard the new Guzzi's, so that's their reference. Are the newer Guzzi's quieter? It runs fine but don't want issues if they're too loose. Link to comment Share on other sites More sharing options...
VA Sean Posted June 11, 2007 Share Posted June 11, 2007 They have only heard the new Guzzi's, so that's their reference. Are the newer Guzzi's quieter? The "new" Breva and Griso 1100 are much quieter valve-train-wise. I am sure if they are a new dealer, only handling the new bikes (no older Calis or Spine frames) then they aren't used to real Guzzi valve noise. Link to comment Share on other sites More sharing options...
Frenchbob Posted June 12, 2007 Share Posted June 12, 2007 I believe that specified valve clearances for US bikes are tiny, perhaps because of the need to satisfy emissions or noise standards. They run better with bigger clearances. The standard European spec is 4 thou on the inlets and 6 thou on the exhausts. I run my V11 Sport at 6 thou on the inlets and 8 thou on the exhaust and I'm happy with that. For bikes that are hard-ridden, I've heard 8 thou inlet and 10 thou exhaust recommended. "A tappy tappet is a happy tappet" If you do an archive search on here, you'll find this and more information, placed there by those who can be trusted to know. What mileage did you get out of your spring, as a matter of interest? Link to comment Share on other sites More sharing options...
kevdog3019 Posted June 12, 2007 Author Share Posted June 12, 2007 Thanks guys. Just wanted to make sure things were fine. Now I know. I have heard the big Breva and (most recently) the Griso and could not beliee how quiet those bikes are from valve train clacking. We got 27000 miles off first spring and when opened up, it had 15mm boss and newer spring (if there is such a thing). The boss was replaced since they pre-ordered it prior to investigating. This is fine since old boss showed slight impression of wear in one spot. It seems to correspond to where the spring failed, so maybe the new boss will remedy it anyhow. Link to comment Share on other sites More sharing options...
Guest ratchethack Posted June 12, 2007 Share Posted June 12, 2007 . . .The boss was replaced since they pre-ordered it prior to investigating. This is fine since old boss showed slight impression of wear in one spot. It seems to correspond to where the spring failed, so maybe the new boss will remedy it anyhow. Won't Get Fooled Again . . . Take a bow for the new revolution Smile and grin at the change all around Take up my guitar and play Just like yesterday And I'll get on my knees and pray We don't get fooled again Yeaaaaaaaaaaaaaaaaaaaaaaaaah! Meet the new boss Same as the old boss -- P. Townshend Sorry, I just had to. Link to comment Share on other sites More sharing options...
kevdog3019 Posted June 12, 2007 Author Share Posted June 12, 2007 Won't Get Fooled Again . . . Take a bow for the new revolution Smile and grin at the change all around Take up my guitar and play Just like yesterday And I'll get on my knees and pray We don't get fooled again Yeaaaaaaaaaaaaaaaaaaaaaaaaah! Meet the new boss Same as the old boss -- P. Townshend Sorry, I just had to. Yes I realize, but I'm looking at the glass as half-full... you are pointing out that it is half empty. Some like the old boss Some like the new boss I'd prefer for no boss It's all such a toss Yeaaaaaaaaaaaaaaaaaaaaaaaaah! Link to comment Share on other sites More sharing options...
callison Posted June 13, 2007 Share Posted June 13, 2007 Yes I realize, but I'm looking at the glass as half-full... you are pointing out that it is half empty. Some like the old boss Some like the new boss I'd prefer for no boss It's all such a toss Yeaaaaaaaaaaaaaaaaaaaaaaaaah! The optimist sees the glass as being half-full. The pessimist sees the glass as being half-empty. The engineer sees the glass as being approximately twice the size it needs to be. Link to comment Share on other sites More sharing options...
badmotogoozer Posted June 13, 2007 Share Posted June 13, 2007 And big bad BMG sees it as time to order another beer... Rj Link to comment Share on other sites More sharing options...
Guest aironepony Posted June 23, 2007 Share Posted June 23, 2007 And big bad BMG sees it as time to order another beer... Rj Mine's a large whisky.................... Link to comment Share on other sites More sharing options...
