Starter Solenoid
andy york
Anyone have a starter solenoid laying around ?
:huh2:
Getting tired of jumping the starter on this road trip
in Charlotte NC.
maybe someone has a cross reference # for one at the auto parts
store ....
lemme know
Andy :luigi:
in Charlotte NC.
store ....
lemme know
Exactly which terminals are you shorting? The two large or one small to one large. If it is the two large, the solenoid is bad. If it is the one small to one large, the problem is in the start circuit.
If it is the secondary of the solenoid on the starter, disassembly and a good scuff with some sandpaper or such of the main contacts will normally allow a good contact for starting. As noted above if your problem is the primary windings or other starter activation circuits you are in for a little more work.
Well I must have other problems....Shorting the big and small terminal....something wrong in
the start circuit somewhere....
i guess its off with the tank so we can have a better look at the situation under there.
more to follow..
andy
more to follow..
andy
Pull relay 1 and try shorting across the 2 big terminals (make sure it's in Neutral first)
That will test from the relay on.
If I were to hazard a guess I would look at the switch on clutch lever, try shorting that out and press start, don't forget the kill switch.
Roy
more to follow..
andy
Jumper the start terminal (small) to the larger terminal (the one with the battery cable) and see what happens.
p.s. Make absolutely sure the bike is in neutral. We will all hear you if it isn't.
  • 2 weeks later...
Well after arriving home it was pull the tank time.
<_>
After disassembly of the starter/kill switch.....nothing at fault. :angry:
check fuses again....15 amp blown...replace....turn on key ....pop!!!
replace fuse again....unplug socket to starter switch...key on ...pop :(
it was time to step away....thinking there is a dead short in the harness
somewhere....i was about to say screw it ..i'll keep jumping it. -_-
pull all the relays....replace fuse...key on...no blown fuse.. :rolleyes:
start putting relays back in one at a time.....pop...fuse blows again... :lol:
Bad relay was the cause of all this.
guess its time for more relays from Dan. I think i get about 4 sets of tires
to a set of relays :lol:
:bier:
andy
I had whatever was the latest greatest :huh2:
dont want to go back out there yet .....you know...
mojo and all :wacko: seems to run now :huh2:
75,000 guess i'll change my relays once a year.
I seem to change them every 16 months cause i have to.
i think that will just be part of my yearly maint.
andy
Was it Relay 1 or 2 causing the fuse to pop? It would take a major melt down for a short between 30/87A to ground
perhaps between the center and adjacent small pin. If you get a chance please run your multimeter over it and possibly remove the cover.
Heres one source I use
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=Z2247-ND $4.82
They also have another part o Z2001-ND @ $7.60, don't know that it would last any longer though
Roy
p.s. I keep telling you guys to substitute a lamp for the fuse when locating a short, but I'm just as guilty one more fuse will fix it!
:oldgit:
actually, I think it was the fuel pump relay....no ...I relay :lol: don't know.
The 15 amp that blew was the fuel pump fuse of which I think the starter button
goes to also :huh2: probably wrong about that to.
I've thought about being methodical in my electric search but in the end, screw it the
bike is running.
I think these bikes have a lot of vibration that causes the contacts in these relays
to bounce around between open and closed. I know its not supposed to be that way
but what else can account for the contacts looking burned. I've seen ignition points with
25-30000 miles on them that looked better than some of these relay contacts.
anyway...yearly relay replacement has been added to my maintenance list....kinda cheap
insurance since this only happens to me when I'm 500 miles from home :race:
later
andy
:mg:
