guzziman1100 Posted June 23, 2010 Share Posted June 23, 2010 Hi everybody, I am being plagued by a bad running problem at the moment, Bike was put away before winter with no problems other than oil leaks and a clutch that was on it's last legs. Came to start the bike up about 2 months ago and she fires up straight away when cold, runs for a couple of minutes and then cuts out, will not start again until absolutely cold again then I get same problem. Recently drained tank and discarded fuel (some contamination in there from water in fuel tank and old filter etc) put new fuel in and a new fuel filter. Started straight away and then cut out a couple of minutes later. Will not start and does not seem to have a spark (new plugs fitted) does not smell of petrol and plugs are not wet. has anyone any ideas please? Best regards, Guzziman 1100 Link to comment Share on other sites More sharing options...
docc Posted June 24, 2010 Share Posted June 24, 2010 Mouse nest in the air filter? The 1100 Sport-i is not a really old Guzzi and the FI is very similar to the V11. If you don't get much response here, let's move the thread to Tech Topics. Link to comment Share on other sites More sharing options...
Admin Jaap Posted June 24, 2010 Share Posted June 24, 2010 Moved Link to comment Share on other sites More sharing options...
raz Posted June 24, 2010 Share Posted June 24, 2010 Swap relays around. Condition your emergency stop switch (just flip it 10 times or so). Link to comment Share on other sites More sharing options...
Tom M Posted June 24, 2010 Share Posted June 24, 2010 Clogged tank vent? Try running it with the gas cap open. Link to comment Share on other sites More sharing options...
dhansen Posted June 25, 2010 Share Posted June 25, 2010 Clogged tank vent? Try running it with the gas cap open. Yup, yup. My first thought. Link to comment Share on other sites More sharing options...
luhbo Posted June 25, 2010 Share Posted June 25, 2010 ...Will not start and does not seem to have a spark ... I'd check the phase sensor. An easy test is to listen to the fuel pump: does the starter trigger the pump? Hubert Link to comment Share on other sites More sharing options...
guzziman1100 Posted June 29, 2010 Author Share Posted June 29, 2010 I'd check the phase sensor. An easy test is to listen to the fuel pump: does the starter trigger the pump? Hubert ignition starts the pump and flicking kill button runs the pump but still no luck, where is the phase sensor? guzziman1100 Link to comment Share on other sites More sharing options...
guzziman1100 Posted June 29, 2010 Author Share Posted June 29, 2010 Swap relays around. Condition your emergency stop switch (just flip it 10 times or so). cleaned relay contacts but still no luck, will swap round next. have worked kill button but this has had no effect. seems like I have no fuel injection and no spark - are these only controlled by the ecu? thanks guzziman1100 Link to comment Share on other sites More sharing options...
luhbo Posted June 29, 2010 Share Posted June 29, 2010 They are controlled by the ECU, yes. The ECU is grounding them, Plus comes via one of the relais which is also triggered by the ECU. The fuel pump hangs on the same line, so this part should work I guess. The phase sensor is sitting on the upper left part of the timing cover, near (below) the oil pressure switch. You can't do very much with it besides checking its resistance. My initial question was: after the pump was priming for the usual 1 or 2 seconds, does it come on again for another few moments after you've pressed the starter button? In other words: does the ECU recognise a moving engine, signalled by the phase sensor? Hubert Link to comment Share on other sites More sharing options...
guzziman1100 Posted June 29, 2010 Author Share Posted June 29, 2010 They are controlled by the ECU, yes. The ECU is grounding them, Plus comes via one of the relais which is also triggered by the ECU. The fuel pump hangs on the same line, so this part should work I guess. The phase sensor is sitting on the upper left part of the timing cover, near (below) the oil pressure switch. You can't do very much with it besides checking its resistance. My initial question was: after the pump was priming for the usual 1 or 2 seconds, does it come on again for another few moments after you've pressed the starter button? In other words: does the ECU recognise a moving engine, signalled by the phase sensor? Hubert I will check this later, thanks for the reply. regards, guzziman1100 Link to comment Share on other sites More sharing options...
guzziman1100 Posted September 13, 2010 Author Share Posted September 13, 2010 They are controlled by the ECU, yes. The ECU is grounding them, Plus comes via one of the relais which is also triggered by the ECU. The fuel pump hangs on the same line, so this part should work I guess. The phase sensor is sitting on the upper left part of the timing cover, near (below) the oil pressure switch. You can't do very much with it besides checking its resistance. My initial question was: after the pump was priming for the usual 1 or 2 seconds, does it come on again for another few moments after you've pressed the starter button? In other words: does the ECU recognise a moving engine, signalled by the phase sensor? Hubert Hubert, many thanks, spot on it was the phase sensor. I can't believe it was June when I first asked for assistance, now the summers gone! nevermind, best ride through the winter then. once again, thanks for the help, best regards, guzziman1100 Link to comment Share on other sites More sharing options...
luhbo Posted September 20, 2010 Share Posted September 20, 2010 Thanks for the feedback, Guzziman. Hope you'll get some fun now out of the rest of the season. They say we should get a wonderfull October now .... Hubert Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted September 21, 2010 Share Posted September 21, 2010 Thanks for the feedback, Guzziman. Hope you'll get some fun now out of the rest of the season. They say we should get a wonderfull October now .... Hubert That was brilliant Hubert, straight on to it. Link to comment Share on other sites More sharing options...
