Greg Field Posted August 1, 2010 Share Posted August 1, 2010 Thanks for the info, Greg Well. The used one I obtained from the dealership did not work out well That hurts just looking at it. My sympathies . . . Link to comment Share on other sites More sharing options...
yamalama Posted August 2, 2010 Author Share Posted August 2, 2010 The Penske shock is on sale this month - 799. Any thoughts on going this route? The Ohlins is approximately 1200. Link to comment Share on other sites More sharing options...
yamalama Posted August 21, 2010 Author Share Posted August 21, 2010 I bought the Penske. Looks like a nicely put together unit. The unit is slightly longer(adjusted short as possible). Barely fit. Rear ride height is increased, probably about an inch. Spring height adjustment requires that one remove the tank, side covers, and air box. Fourth shock removal,in 7000 miles. Getting good at it! Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted August 21, 2010 Share Posted August 21, 2010 Fourth shock removal,in 7000 miles. Getting good at it! So I know where to come when mine gives out, glad you are back on the road. Roy Link to comment Share on other sites More sharing options...
gstallons Posted August 21, 2010 Share Posted August 21, 2010 I bought the Penske. Looks like a nicely put together unit. The unit is slightly longer(adjusted short as possible). Barely fit. Rear ride height is increased, probably about an inch. Spring height adjustment requires that one remove the tank, side covers, and air box. Fourth shock removal,in 7000 miles. Getting good at it! Are you Jason Britton ? Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted August 22, 2010 Share Posted August 22, 2010 [Are you Jason Britton ? No, he's not, he's the lone ranger, at least that's what he told me Link to comment Share on other sites More sharing options...
