Skeeve Posted September 9, 2010 Share Posted September 9, 2010 I will check out the Motion Pro tool also. Hobby shop: section of brass tubing = $5 Hardware store: suitably sized drill stop or similar, & some rubber hose to fit tubing = $10 Pharmacy: Oral syringe = $5 ----------------------------------- Total = $20; $15 savings over the Motion Pro tool, & that's only if you don't already have most of the components sitting around the garage as "useful scrap." For 90% of the motorcyclists who have a garage of their own, the total outlay is going to be $5 or less... For instance, forget the drill stop, a block of wood sized so it won't fall into the fork tube w/ a suitably sized hole for the tubing drilled thru it will be a better solution than the drill stop, & is $0 cost. C'mon, get creative. Google an image of the MP tool & reverse engineer it: it's not that complicated! Link to comment Share on other sites More sharing options...
docc Posted September 9, 2010 Share Posted September 9, 2010 While you have the wheel off, check out the FAQ Maintenance Checklist . It's especially good to get all eight brake pistons moving evenly again! Link to comment Share on other sites More sharing options...
