2or4strokes Posted April 17, 2011 Share Posted April 17, 2011 Hello anyone knows what is the nitogen gas charged pressure for our white power rear shocks on the sports 1100i? My shock builder put in 9 bar and it feels too hard. Link to comment Share on other sites More sharing options...
GuzziMoto Posted April 18, 2011 Share Posted April 18, 2011 Not sure exactly what pressure is spec'd for that shock but in my experience 140 - 150 psi (around 10 bar I believe) is typical. Link to comment Share on other sites More sharing options...
2or4strokes Posted April 19, 2011 Author Share Posted April 19, 2011 Not sure exactly what pressure is spec'd for that shock but in my experience 140 - 150 psi (around 10 bar I believe) is typical. Hmm 9 bar feels a little harsh , I'm now trying 8 with compression and rebound at 1 position(minimum) . Ok maybe someone will know the exact specs although I think you're probably right because most suspension manufacturer recomends 9 to 10 bar. Link to comment Share on other sites More sharing options...
richard100t Posted April 19, 2011 Share Posted April 19, 2011 Most manufacturers set the bike up to handle the bikes maximum GVWR I THINK. If you're under 180 and ride without a partner on the back the stock setup probably will feel too harsh. I replaced the fork springs with progressives from Hyperpro and still wasnt satisfied until I swapped the 10wt fork oil for a 5 wt. After that it seems to all work like its supposed to work. I would think the same applied to the shock. Try a lighter weight oil and maybe back the pressure off 5%. Link to comment Share on other sites More sharing options...
GuzziMoto Posted April 19, 2011 Share Posted April 19, 2011 The main purpose of the pressure in the shock is to prevent the oil from foaming. While the pressure does add a little to the stiffness of the shock that is not its primary role. If you want a softer shock change the spring or the oil/dampening. Link to comment Share on other sites More sharing options...
2or4strokes Posted April 23, 2011 Author Share Posted April 23, 2011 The main purpose of the pressure in the shock is to prevent the oil from foaming. While the pressure does add a little to the stiffness of the shock that is not its primary role. If you want a softer shock change the spring or the oil/dampening. Most manufacturers set the bike up to handle the bikes maximum GVWR I THINK. If you're under 180 and ride without a partner on the back the stock setup probably will feel too harsh. I replaced the fork springs with progressives from Hyperpro and still wasnt satisfied until I swapped the 10wt fork oil for a 5 wt. After that it seems to all work like its supposed to work. I would think the same applied to the shock. Try a lighter weight oil and maybe back the pressure off 5%. Thanks to both of you for the info. Will try to find a lower poundage spring but do you know what can fit the white power or the standard ratings for the original springs? Link to comment Share on other sites More sharing options...
richard100t Posted April 23, 2011 Share Posted April 23, 2011 The main purpose of the pressure in the shock is to prevent the oil from foaming. While the pressure does add a little to the stiffness of the shock that is not its primary role. If you want a softer shock change the spring or the oil/dampening. Most manufacturers set the bike up to handle the bikes maximum GVWR I THINK. If you're under 180 and ride without a partner on the back the stock setup probably will feel too harsh. I replaced the fork springs with progressives from Hyperpro and still wasnt satisfied until I swapped the 10wt fork oil for a 5 wt. After that it seems to all work like its supposed to work. I would think the same applied to the shock. Try a lighter weight oil and maybe back the pressure off 5%. Thanks to both of you for the info. Will try to find a lower poundage spring but do you know what can fit the white power or the standard ratings for the original springs? It might be a good idea to change the oil in the shock to a lighter weight first. It will be cheaper than a spring and will definitely not do any harm. as long as you dont gain 100lbs or decide to haul a huge partner on it If its still too stiff after that change the fork oil to 5wt. If its STILL too stiff after that then buy the lighter springs. I'm betting the oil changes will surprise you. Link to comment Share on other sites More sharing options...
2or4strokes Posted April 23, 2011 Author Share Posted April 23, 2011 The main purpose of the pressure in the shock is to prevent the oil from foaming. While the pressure does add a little to the stiffness of the shock that is not its primary role. If you want a softer shock change the spring or the oil/dampening. Most manufacturers set the bike up to handle the bikes maximum GVWR I THINK. If you're under 180 and ride without a partner on the back the stock setup probably will feel too harsh. I replaced the fork springs with progressives from Hyperpro and still wasnt satisfied until I swapped the 10wt fork oil for a 5 wt. After that it seems to all work like its supposed to work. I would think the same applied to the shock. Try a lighter weight oil and maybe back the pressure off 5%. Thanks to both of you for the info. Will try to find a lower poundage spring but do you know what can fit the white power or the standard ratings for the original springs? It might be a good idea to change the oil in the shock to a lighter weight first. It will be cheaper than a spring and will definitely not do any harm. as long as you dont gain 100lbs or decide to haul a huge partner on it If its still too stiff after that change the fork oil to 5wt. If its STILL too stiff after that then buy the lighter springs. I'm betting the oil changes will surprise you. Hi Richard You're saying that the original is 10wt and changing it to a 5wt helps. Any idea what is the quantity of oil needed at least originally? Link to comment Share on other sites More sharing options...
richard100t Posted April 23, 2011 Share Posted April 23, 2011 The main purpose of the pressure in the shock is to prevent the oil from foaming. While the pressure does add a little to the stiffness of the shock that is not its primary role. If you want a softer shock change the spring or the oil/dampening. Most manufacturers set the bike up to handle the bikes maximum GVWR I THINK. If you're under 180 and ride without a partner on the back the stock setup probably will feel too harsh. I replaced the fork springs with progressives from Hyperpro and still wasnt satisfied until I swapped the 10wt fork oil for a 5 wt. After that it seems to all work like its supposed to work. I would think the same applied to the shock. Try a lighter weight oil and maybe back the pressure off 5%. Thanks to both of you for the info. Will try to find a lower poundage spring but do you know what can fit the white power or the standard ratings for the original springs? It might be a good idea to change the oil in the shock to a lighter weight first. It will be cheaper than a spring and will definitely not do any harm. as long as you dont gain 100lbs or decide to haul a huge partner on it If its still too stiff after that change the fork oil to 5wt. If its STILL too stiff after that then buy the lighter springs. I'm betting the oil changes will surprise you. Hi Richard You're saying that the original is 10wt and changing it to a 5wt helps. Any idea what is the quantity of oil needed at least originally? I dont know how much you'll need for your bike. My 01 rosso mandello uses 400ml in each fork leg, so if you buy a quart of fork oil that should be enough. Do the forks first, because I think thats probably going to solve most or all of your problem with the too stiff ride. Link to comment Share on other sites More sharing options...
