j_o_h_a_n_v Posted July 28, 2016 Share Posted July 28, 2016 Hello, I'm having trouble with my stator. I would like to replace it. Affordably I can only find the stator without the housing. But how is such a stator fixed to the housing? Glue? How to you get it to come out? And more importantly even: how do you get a new one back in? Thanks! Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted July 28, 2016 Share Posted July 28, 2016 Just 4 screws I think, may need to lever it out with a screwdriver to the steel part, don't lever on the coils. How do you know it's faulty? Measure the resistance between yellow wires, about 0.3 Ohms is normal, if it's open circuit inspect where the yellow wires are soldered to the coils. With the bike idling you should read 15 - 20 VAC between the two yellow female bullet connectors, this will rise to about 50 VAC at 3000 revs NOTE: The Volts here is AC (Alternating Current) not DC like the rest of the bike. Link to comment Share on other sites More sharing options...
gstallons Posted July 28, 2016 Share Posted July 28, 2016 I'm with Kiwi Roy , how did you conclude the stator is bad ? The rotor is attached to the c/shaft end and the stator is attached to the timing cover . Link to comment Share on other sites More sharing options...
MartyNZ Posted July 28, 2016 Share Posted July 28, 2016 V11Sport Alternator.pdf As KiwiRoy said, it is held in with screws. See picture attached, which should answer your question "But how is such a stator fixed to the housing? Glue? How to you get it to come out? And more importantly even: how do you get a new one back in?". My alternator problems were cured by repairing bad connections in the yellow wires from the stator to the regulator, fitting a better 30A fuseholder than the one under the seat, and properly grounding the regulator. Marty Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted July 28, 2016 Share Posted July 28, 2016 Note; You don't have to pull off the rotor to remove the stator as it shows in the diagram Marty posted, that's more for if you need to remove the timing cover. 1 Link to comment Share on other sites More sharing options...
