I don't know anything about this model or engine. That said I just worked on my Griso with a similar sounding noise. That was down to a camchain tensioner not getting enough oil so it couldn't get up to pressure to tension the camchain.
If the bike has been standing there could be a buildup of sludge in a hydraulic component that is causing the item to not work as designed.
Good luck
The VFR is cam driven, usually they are bulletproof. Checked the front pots, cams and buckets looked ok, one inlet valve was below the tolerance by quite a long way, so i may as well correct that, but gut instinct tells me its something more serious
  • 4 weeks later...
