2002 LeMans electrical
JRD
Yeah, much simpler to only use the 5 pin relays. That way all relays are interchangeable, and if you carry a spare or two you know it will work in any position.
On 7/18/2023 at 12:07 PM, JRD said:
Ok folks I finally found my electrical problem and it was probably self inflicted. After initially checking all the fuses and replacing each relay EXCEPT the START relay, I removed all of the body work and began checking each individual junction plug to include disassembling the ignition switch.  When all that failed I called a friend who went thru each circuit.  We then discovered at some point I must have inserted a 4 blade relay into the STARTER relay plug.  This relay also supplies energy to the brake light, headlights and horn relay via the green/white wire.  PROBLEM SOLVED!!!!  We also learned the fuse for the fuel pump activate the starter when I discovered a brand new faulty fuse.  Thanks so much to Docc and everyone, especially for posting the wire diagram!!!!!
See you at the Tennessee Spine Raid!!
