docc Posted August 14 Posted August 14 1 hour ago, skibum69 said: Back again. Phil you sent me the link for 2 different master cylinders. I take it from those links that mine is the 16mm version? I wouldn't know how to even check that. I only ask because I stupidly looked at a 13mm on one of those websites. Yessir, front brake master cylinder is 16mm.
docc Posted August 15 Posted August 15 2 hours ago, skibum69 said: Thank you. Ordering a new one now. Just for confirmation, look at the top of your master cylinder housing just ahead of the lever pivot for a stamping that ends in "16" . . . 1
skibum69 Posted August 16 Author Posted August 16 You're talking the "16" you can see in this photo? 2
docc Posted August 16 Posted August 16 6 minutes ago, skibum69 said: You're talking the "16" you can see in this photo? Yessir! 2
gstallons Posted 6 hours ago Posted 6 hours ago Fuel for the fire. When the time comes for maintenance on your pad replacement. (In case you didn't know) Wagner and others sell a DOT 5.1 brake fluid . It works in all systems that have DOT 3 and DOT fluid applications. This is also NOT compatible w/DOT 5. Nothing is and don't forget it. The min. wet boiling point is 356f / 180c temp. so you should be good and not experience bad things riding over your head ! 1
