dukdark750 Posted November 2, 2004 Share Posted November 2, 2004 I just bought this blike and I love it...with a few exceptions....The tach drive seems to only work every so often???? any ideas....I've been real busy and haven't had time to actually look it over..but the previous owner told me that the dealer had fixed this already as part of the recall?????...any help would be much appreciated!!! by the way this is one of the best bike specific sites I have ever come across!!!! Brian in New Jersey 2000 v11 2000 ducati monster dark 1969 Royal enfield 750 iNterceptor 1966 Re cont. Gt 250 Link to comment Share on other sites More sharing options...
Guest Bruce Posted November 2, 2004 Share Posted November 2, 2004 This doesn't directly answer your question but... My tach died a couple months ago and I've been too busy to get into it. So I've been ridding w/o and finding that the damn thing was pretty much a distraction anyway and that I prefer not having it! There is also allot of tach info on the forum. Link to comment Share on other sites More sharing options...
rossoandy Posted November 2, 2004 Share Posted November 2, 2004 I just bought this blike and I love it...with a few exceptions....The tach drive seems to only work every so often???? any ideas....I've been real busy and haven't had time to actually look it over..but the previous owner told me that the dealer had fixed this already as part of the recall?????...any help would be much appreciated!!! by the way this is one of the best bike specific sites I have ever come across!!!! Brian in New Jersey 2000 v11 2000 ducati monster dark 1969 Royal enfield 750 iNterceptor 1966 Re cont. Gt 250 36548[/snapback] hi andy here , when my v1100 tacho played up it stopped charging too, was found to be poor connection under one of those underseat relays.try wigglin the wires around there. rossoandy uk Link to comment Share on other sites More sharing options...
al_roethlisberger Posted November 3, 2004 Share Posted November 3, 2004 Before "writing the tach off" as failed, check out the following thread: http://www.v11lemans.com/forums/index.php?showtopic=3282&hl= ....it may simply be a loose ground inside the nacelle. al Link to comment Share on other sites More sharing options...
Guest jasper Posted November 3, 2004 Share Posted November 3, 2004 my tach died on me after about 20000 km but it is possible to fix the tach's got mine fixed and is working like a charm again.. ciao jasper Link to comment Share on other sites More sharing options...
MickM Posted November 8, 2004 Share Posted November 8, 2004 I just bought this blike and I love it...with a few exceptions....The tach drive seems to only work every so often???? any ideas....I've been real busy and haven't had time to actually look it over..but the previous owner told me that the dealer had fixed this already as part of the recall?????...any help would be much appreciated!!! I had the exact same problem. Somewhere in the site there's instructions on running an additional earth return from one of the instrument mounting screws to the crankcase and then from crankcase to battery. Obviously doesn't matter exactly where you place the terminals but I remember I went from the right side of the crankcase/gearbox mating face as the easiest to access when going to the battery. You have to look extremely hard to find any of it and tach worked, completely, 100 % from that day on. I used to also have a bit of a problem with losing battery charge in storage and this fix also completely cured that as well .... best hour you'll ever spend. Link to comment Share on other sites More sharing options...
Guest oldtoolie Posted November 21, 2004 Share Posted November 21, 2004 I had that problem too. Cured by replacing the relays and cleaning electrical connectors under the tank. Link to comment Share on other sites More sharing options...
