Relays
k7qz
Hi Guys:
One of the ponies in my stable is an '03 LeMans and I seem to be the latest victim of the dreaded relay failure. LD (who is very good) was going to order OEM parts, but I told him I'd just order them myself as I recall having read a post here on this subject a while back. The sentiment seemed to be that there were superior alternatives to Guzzi's relay offerings.
I was thinking about replacing all of the relays while I'm at it (5 of them as I recall from skimming the schematic but I might not be remembering this correctly...) and was wondering if you think this is worthwhile? Also any current recommendations on relay sources?
TIA-
Mike
Hi Guys:
TIA-
Mike
73948[/snapback]
Hi Mike, 5 is the correct count.
Many people here have had good sucess with an online site. Details can be found here: http://www.v11lemans.com/forums/index.php?...indpost&p=70470
A search on "relays" will bring up many results, regards.
Guest ratchethack
Wot they said. Dan P's THE Guzzi Relay Man. :thumbsup:
I always thought his nickname, "Pyro Dan" was slightly suspicious for a "relay guy". <_<:o
When I politely inquired about this, Dan graciously explained that he does pyrotechnic design work - which of course requires a certain mastery of electronically controlled relays. :doh:
Thanks all for the replies.
Yes, per earlier relay posts on this site I had e-mailed Dan but didn't receive a response. So I wasn't sure if he had faded into non-existence. Hence my query regarding current relay sources.
I'll try shooting Dan another e-mail as it sounds as if he is alive and well in the relay business.
Regards-
Mike
Regards-
Mike
74019[/snapback]
Know the Rules
:bier:
Know the Rules
:bier:
74021[/snapback]
I like the Know The Rules link...real time saver. :bier:
You could expound on a few more rules..clutch switch/connector..kickstand switch..
neutral switch...tank suck..vap lock..shift spring...
Ha!! You could pare the whole forum down to one page. :bier:
Untill ratchet rattles the cage with an oil or filter post...then we'd be back
to a couple thousand pages. :P
74024[/snapback]
Heh! I shouldn't laugh, as I am responsible for a good portion of those pages, especially the ECU thread :drink:
. . . Untill ratchet rattles the cage with an oil or filter post...then we'd be back to a couple thousand pages.  :P
74024[/snapback]
I like rachethacks posts! :drink:
