Scud Posted July 29, 2017 Share Posted July 29, 2017 Not mine... no association with seller... just noticed a very good price on a complete, low-mileage clutch. Good option for anybody still needing to replace a single-plate unit in a Scura or Tenni. You'd just need to buy a new transmission input hub, and maybe some new springs. While this is out of a Breva, you can see that it is the same 10-spring configuration as the V11 clutch. http://www.ebay.com/itm/MOTO-GUZZI-BREVA-V1100-V11-06-1100-CLUTCH-HUB-FLYWHEEL-STARTER-GEAR-DISCS-PLATES-/272609004582?hash=item3f78c34c26:g:~CkAAOSwaeRZJH5N&vxp=mtr Link to comment Share on other sites More sharing options...
docc Posted July 29, 2017 Share Posted July 29, 2017 Not mine either, but I've had positive dealings with this seller. All of the part numbers check out between the V11 and Breva 1100 except the friction plates (as I recall) - so worth investigating that (likely just a superseded part). MotoInternational (Seattle, WA, USA) lists the "Input Hub for 2-plate V11" 04211600 for $125.45US. I have not checked availability. http://www.motointernational.com/store//input-hub-for-2-plate-v11s Be sure to replace the "lock washer" as well: http://www.motointernational.com/store/product/GU95028025 [Links for reference only. Not a promotion.] Link to comment Share on other sites More sharing options...
