Tomchri Posted March 11, 2019 Share Posted March 11, 2019 Didnt look at my headers when I took them of. My AFC is about 1 turn out. More fuel in the right cylinder than the left. She was running fine before she quit charging. What is the first that comes to the experienced injection guys mind? Trying to play with the AFC before balancing? See pictures. Cheers tom Sent fra min SM-G903F via Tapatalk Link to comment Share on other sites More sharing options...
docc Posted March 12, 2019 Share Posted March 12, 2019 Tom, if it stopped charging, perhaps it was not so much rich on one side, but simply not firing (and burning the mixture) well? Why not get her charging, do a complete tune-up and ride the first chance you get. Recheck the plugs and decide if the problem has solved itself . . . 1 Link to comment Share on other sites More sharing options...
LowRyter Posted March 12, 2019 Share Posted March 12, 2019 Might try some Seafoam? The large economy size. Link to comment Share on other sites More sharing options...
fotoguzzi Posted March 12, 2019 Share Posted March 12, 2019 Why did you take off the headers? Check plug wires/caps.. are they seated in the coils nice and tight. Link to comment Share on other sites More sharing options...
Tomchri Posted March 12, 2019 Author Share Posted March 12, 2019 All ideas are welcomed. Docc had an idea, will follow that. Headers of, for checking stator, concerning my charging problem. And still hoping to find a Stucci cross over. Seafoam for cleaning injectors, will check that to. Cheers tom. Link to comment Share on other sites More sharing options...
MartyNZ Posted March 15, 2019 Share Posted March 15, 2019 On 3/13/2019 at 3:56 AM, Tomchri said: Seafoam for cleaning injectors, will check that to. Cheers tom. Injector cleaning by adding a cleaner to the fuel will help by disolving varnish/wax deposits, so can give good results. However some insoluable particles which get past the filter can lodge in the injectors, and only back-flushing or disassembly can clean that. I had brown fuzz in the inlet screens of my injectors, so I suspected some could be inside the injectors. I made two injector back-flushing kits, thanks to some help from Scud, and can mail you mine if you want to use it. ...and the 5 Dec 2016 post here: https://www.v11lemans.com/forums/index.php?/topic/18805-brand-new-scura/&do=findComment&comment=215317https://www.v11lemans.com/forums/index.php?/topic/18805-brand-new-scura/&do=findComment&comment=215317 1 Link to comment Share on other sites More sharing options...
