rich888 29 Posted March 17 Report Share Posted March 17 Anyone able to post a pic of the steering damper? Specifically, the rod end fixings where it attaches to the forks. There are two dished washers. Do these go either side of the rod end ball? I assume they cup the spherical bearing? Thanks. Quote Link to post Share on other sites
Lucky Phil 2,007 Posted March 17 Report Share Posted March 17 35 minutes ago, rich888 said: Anyone able to post a pic of the steering damper? Specifically, the rod end fixings where it attaches to the forks. There are two dished washers. Do these go either side of the rod end ball? I assume they cup the spherical bearing? Thanks. Yes they do correct. Ciao 1 Quote Link to post Share on other sites
docc 3,762 Posted March 17 Report Share Posted March 17 1 hour ago, Lucky Phil said: Yes they do correct. Ciao 1 Quote Link to post Share on other sites
Lucky Phil 2,007 Posted March 18 Report Share Posted March 18 7 hours ago, Steve S said: The dished washers go the other way or the movement will be restricted Nope, the whole idea is the movement is restricted so the damper unit doesn't flop around. It's just not restricted enough to stop it pivoting as it should when the steering is turned. Ciao 1 Quote Link to post Share on other sites
Steve S 111 Posted March 19 Report Share Posted March 19 Okay I’ll swap my washers around then 1 Quote Link to post Share on other sites
Join the conversation
