You aren't gonna think much of me for this...but...
...a mini disc grinder to grind thru the bearing cage to split it. Sounds worse than it is - a bit at a time, don't have to cut clean thru it, just enough to get it to shift.VERY SLOW & CAREFUL. Done it a couple times - no problems ...
KB, Cymru
Docc,
2,700 miles out of Diablos on Scura, Mostly fairly hard on dry roads. These were normal Diablos - you can get Diablo Corsas which are stickier, wear quicker (I'm told). I got 3,300 out of 020's & much prefer the Diablos.
KB, Cymru
On Any Sunday, Hells Angels on Wheels, The Great Escape, Mad Max, Stone, Any of the on bike TT films, that George Formby TT film think it was No Limits, that ol brit film about Ton Up Boys risen from the dead ... On Any Sunday &...On AnySunday.
The Ohlins are wonderful things & if you can afford the extra, well worth having. Only thing is cos they have such a range of adjustment they can take a bit of setting up right.
KB,Cymru
Same here. My 02 weeps from somewhere around lower part of plate that holds selector mechanism, pos shift seal or some other fixing on the plate. Reseal didn't fix. Not enough to worry about.
KB, Cymru
...another problem with the single plate - turns once considerate people bitter & vindictive...
david s. UJ OK? lots of lash hammers them & everything else.
KB, Cymru
The crank/flywheel assy spinning f/r holds the bike into a right but will tend to lift it out of a left - so right feels steadier. You get used to it. You're thinking too much, look a bit further down the road, bigger picture.
KB, Cymru
The crank, flywheel/clutch all spinning along f/r axis pull it down or push it up depending on right or left corner & revs throttle on/off...it's noticeable just blipping the throttle stationary in neutral. Try it airborne over a hump back bridge at speed...
You don't have roundabouts over in the States do you?
KB, Cymru
We should all keep constantly in mind the words of Bento: "...just remember that 80%of the time tirg gear is NOT your friend..."....
In my car I can miss tirg out altogether...
KB, Cymru
Looks like the bushings are a cheapskate solution but I think harshness is just cos of so much unsprung wt there - can't see bush making it much worse. Is there any reason that there needs to be some damping on these pivots or would a freemoving bearing always be better?
KB, Cymru
