Denis Posted April 20, 2012 Share Posted April 20, 2012 Hi I am very interested in buying a 2003 Tenni - low miles in excellent condition. My only concern is that I've read reports about the clutch exploding with the single plate clutches. I'm pretty sure the Tenni has a single plate clutch. Any advice greatly appreciated. I'd even consider buying the bike with a view to changing the clutch out to the conventional two plate system, any pointers to previous threads? I've done a search but can't seem to find much info on the Tenni clutch. Regards Denis Link to comment Share on other sites More sharing options...
mznyc Posted April 20, 2012 Share Posted April 20, 2012 Hi I am very interested in buying a 2003 Tenni - low miles in excellent condition. My only concern is that I've read reports about the clutch exploding with the single plate clutches. I'm pretty sure the Tenni has a single plate clutch. Any advice greatly appreciated. I'd even consider buying the bike with a view to changing the clutch out to the conventional two plate system, any pointers to previous threads? I've done a search but can't seem to find much info on the Tenni clutch. Regards Denis Hi Dennis I can currently converting my Scura single plater to a twin plate.just pulled the motor last night.not that big a deal.Took me a few hours and I'd never done it before and I'm a average home mechanic not a multiple Guzzi/decade owner like many of our other members. I have not heard of the Tenni exploding,only the Scuras.Same clutch assembly as far as I know,don't know why the Scuras would be susceptible to failure. I have a thread in the technical section about this conversion,I'll be updating with pics and info soon if you want to get info if you've never pulled a Guzzi motor,such as me. I got my twin plater from reboot in France .peter is a great guy,real Guzzi enthusiast, and has a very good reputation amongst the members. All the V11's are nearly identical mechanically,but I would consider a model with the Ohlins,especially the 04's(Rossi,Nero,Cafe Sport) as most issues had been worked out and the extra K or so you'll pay will give you about 4k's worth of suspension .Best handling bike I've ever owned. Michael Link to comment Share on other sites More sharing options...
nigelm Posted April 20, 2012 Share Posted April 20, 2012 Hi Denis I had a Tenni a couple of Guzzis ago. The Tenni along with the Scura has a lightweight racing clutch. I f you do a search failure is well documented. I followed the advice, at the time, and had a RAM replacement fitted. This was sourced from Agostini. If you are going to use a dealer it will not be cheap as it is an engine out of frame job. I have a Stelvio now but do miss my Tenni. Good luck, Nigel Link to comment Share on other sites More sharing options...
Denis Posted April 20, 2012 Author Share Posted April 20, 2012 Hi Denis I had a Tenni a couple of Guzzis ago. The Tenni along with the Scura has a lightweight racing clutch. I f you do a search failure is well documented. I followed the advice, at the time, and had a RAM replacement fitted. This was sourced from Agostini. If you are going to use a dealer it will not be cheap as it is an engine out of frame job. I have a Stelvio now but do miss my Tenni. Good luck, Nigel Thanks for the advice - I think I'll decline the Tenni - I wouldn't have the patience / tools / skill to tackle this job, it would be not financially worth the risk etc. Link to comment Share on other sites More sharing options...
Chuck Posted April 20, 2012 Share Posted April 20, 2012 Hi Denis I had a Tenni a couple of Guzzis ago. The Tenni along with the Scura has a lightweight racing clutch. I f you do a search failure is well documented. I followed the advice, at the time, and had a RAM replacement fitted. This was sourced from Agostini. If you are going to use a dealer it will not be cheap as it is an engine out of frame job. I have a Stelvio now but do miss my Tenni. Good luck, Nigel Thanks for the advice - I think I'll decline the Tenni - I wouldn't have the patience / tools / skill to tackle this job, it would be not financially worth the risk etc. I think that's a good decision if you can't do the work. Look for any LeMans or the 03-04 V11s. Link to comment Share on other sites More sharing options...
