Trouble Light
Kiwi_Roy
This idea went down like a lead balloon over on the other site I post
Let see if it floats here :oldgit:
The light will flicker or dim if you have a bouncing sidestand or bad switch contact.
I prefer to use a 12 Volt LED for this, they are easy to see in bright sunlight if pointing in the general direction of your eye
This is not intended as a permanent installation just string the wire across the tank to the fusebox.
If you don't have an electric petcock wrap the wire around the relay pin.
I haven't shown any detail of the ECU circuit because that wiring is very reliable.
