bikelee Posted August 27, 2013 Share Posted August 27, 2013 I'm taking the rear wheel off of my 2003 LeMans Rossa to do a tire change. While I have the wheel off I'm gonna check the wheel bearings and the rear brake caliper pistons for crud on them. Anything else I should check ? Thanks !! Link to comment Share on other sites More sharing options...
gstallons Posted August 27, 2013 Share Posted August 27, 2013 check the wheel bearings , inspect the brake pads and grease the driveshaft. Link to comment Share on other sites More sharing options...
docc Posted August 27, 2013 Share Posted August 27, 2013 Maintenance Checklist in the Frequently Asked Questions sub-forum. Link to comment Share on other sites More sharing options...
mznyc Posted August 27, 2013 Share Posted August 27, 2013 It really should have read "Rear End Maintenance" or "Things to do with the rear wheel off" as a title.Would make it easier to find,... Link to comment Share on other sites More sharing options...
docc Posted August 27, 2013 Share Posted August 27, 2013 It used to read "Maintenance Checklist / While the Rear Wheel is Off." Somehow, the secondary title disappeared. Per your good suggestion it now reads: Wheels Off Maintenance Checklist Link to comment Share on other sites More sharing options...
fotoguzzi Posted August 27, 2013 Share Posted August 27, 2013 grease DS but when you do the center zirk--- have the axle in place so it does not expand length of shaft or it's a bitch to get it back in when over full of grease. Link to comment Share on other sites More sharing options...
mznyc Posted August 28, 2013 Share Posted August 28, 2013 Thanks Docc,I had thought it was easier to find in the past. Link to comment Share on other sites More sharing options...
