Tommy Molotov Posted June 28, 2014 Share Posted June 28, 2014 The end is all chewed up. I put a new one in, but even the new one sits too low for the valve adjustment screw to properly reach. Before I start tearing things apart, what should I expect? Link to comment Share on other sites More sharing options...
fotoguzzi Posted June 29, 2014 Share Posted June 29, 2014 the cam or the follower are disintegrating? I wouldn't ride it.. have you got the Roper plate? oil starvation comes to mind.. Link to comment Share on other sites More sharing options...
Tommy Molotov Posted June 29, 2014 Author Share Posted June 29, 2014 Could be I guess. I don't have the Roper plate. Oil's always been kept at the right levels, so I don't know what to make of it. Link to comment Share on other sites More sharing options...
pete roper Posted June 29, 2014 Share Posted June 29, 2014 Cams and tappets are fed by splash, plate won't help there. If the adjuster won't take up the slack though the only real option unless the pushrod has collapsed is a buggered cam and tappet. Pete Link to comment Share on other sites More sharing options...
Lucky Phil Posted July 4, 2014 Share Posted July 4, 2014 The cam and lifter have failed and the greatly increased valve clearance thus created has hammered the pushrods into what you now have. Ciao The cam and lifter have failed and the greatly increased valve clearance thus created has hammered the pushrod into what you now have. Ciao Link to comment Share on other sites More sharing options...
