Guest Warren Rhen Posted January 14, 2004 Share Posted January 14, 2004 Well my 02 Le Mans that I just brought with 1500 miles on it has left me sit. I put about 50 miles on it today in 20 degree weather and everything works perfect. Then I decided to rotate the shift lever on the trans to reverse the shift pattern to make it the same as the rest of my bikes. Everything was fine but I wanted to lengthen the adjustable rod a little to get the hieght right.when I went out to road test again nothing worked right or consistant. It wouldn't shift down. It wouldn't go out of neutral sometimes and then it wouldn't get out of third or forth. Nothing worked right. I say a thread on the forum about springs in the trans. Does this sound like those symtoms? Can you change them without removing the trans? Did you guys get any of the new ones made yet? TIA Link to comment Share on other sites More sharing options...
docc Posted January 14, 2004 Share Posted January 14, 2004 Warrren, It sounds more like the throw might be bringing the lever in contact with the starter cover. Although I'm a lttle cofused about your changing the pattern. 1-up,5-down? You have the lever pointing backwards? What? Link to comment Share on other sites More sharing options...
Guest Warren Rhen Posted January 14, 2004 Share Posted January 14, 2004 Yes, 1 up 5 down It fells so much more natural to me and I've changed every bike I've had since about 96 to that pattern. It's too hard trying to remember which way to shift if you own a couple bikes with different shift pattern. Yes the shift lever othe splined shaft is now facing rearward. I checked the clearance everywhere and it was OK. I evenchanged it back to the way it should be and it still won't shift right. Link to comment Share on other sites More sharing options...
docc Posted January 14, 2004 Share Posted January 14, 2004 There's no chance you moved the adjusting nut just in front of the splined shaft? Or that the pawl is fowling on that? Link to comment Share on other sites More sharing options...
Murray Posted January 14, 2004 Share Posted January 14, 2004 If the shifter spring was broken it would shift at all in ethier direction the leaver would also flop to the bottom of its travel. Link to comment Share on other sites More sharing options...
Baldini Posted January 14, 2004 Share Posted January 14, 2004 Try putting it back as std - see if it works ok? KB, Cymru Link to comment Share on other sites More sharing options...
Guest Warren Rhen Posted January 15, 2004 Share Posted January 15, 2004 Problem solved. When I put it back to the stock shift pattern I moved it one spline too many and it was interferring with the nut in front of it. Thanks guys Link to comment Share on other sites More sharing options...
emry Posted January 18, 2004 Share Posted January 18, 2004 Here is how I did my reverse shifter. Link to comment Share on other sites More sharing options...
Mike Stewart Posted January 18, 2004 Share Posted January 18, 2004 Here is how I did my reverse shifter. Emry, Great job! , do you have the same amount of shifter throw as the stock setup, or did your conversion make for a less throw? Thanks, Mike Link to comment Share on other sites More sharing options...
emry Posted January 18, 2004 Share Posted January 18, 2004 The shift is shorter than stock now. I like it much better, I haven't had a problem with false neutrals since I changed. I used to get them quite frequently. Link to comment Share on other sites More sharing options...
Guest Warren Rhen Posted January 18, 2004 Share Posted January 18, 2004 Thanks OG. I did a similar deal with my Gran Canyon. I just thought I could get away without making anything for the LeMans. But I will change it because I'm so used to it now and I like it so much better than the standard way. The first bike I changed it on was a Buell S3T back in 97. I scared myself a couple of times by almost ripping my foot off by having it under the shifter to shift up while still being leaned over exiting a turn. Since then it has become so natural I can never rember how to shift on a stock shifter Link to comment Share on other sites More sharing options...
